Thread: fault codes
    Regular Member fiend61's Avatar
    Nov 2011
    york
    Vehicle : vectra 2.8 turbo
    Trim : elite
    Engine : 2.8 turbo
    Default fault codes
    hi all
    is there a list of fault codes for the vec-c on here ??? i cant find it
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Nov 2011
    york
    Trim : elite
    Engine : 2.8 turbo
    thanks for that
    ok after attempting to do my thermostat, which couldnt be done due to a fubared torq and its sunday, i cleaned my throttle body and put everything nack together, i now have fault codes and spanner light is coming on when you turn key to position 2 but when you start up engine it goes out, car is running fine but fault codes are
    0110
    0300
    0301
    0302
    0306
    can anyone throw some light on what i might have done/not done as said car is running fine ???
    tia
    Nov 2011
    york
    Trim : elite
    Engine : 2.8 turbo
    anybody please need to know? if i have done something daft
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Dunno what the first one is for the but others are mis fire codes.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    If it's running ok after 25 good starts they should disappear
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    P0110 Intake Air Temperature Circuit Malfunction
    P0300 Random/Multiple Cylinder Misfire Detected
    P0301 Cylinder 1 Misfire Detected
    P0302 Cylinder 2 Misfire Detected
    P0303 Cylinder 3 Misfire Detected
    P0304 Cylinder 4 Misfire Detected
    P0305 Cylinder 5 Misfire Detected
    P0306 Cylinder 6 Misfire Detected
    Nov 2011
    york
    Trim : elite
    Engine : 2.8 turbo
    ok hope thats the case been through everything i have touched and everything ok and car running fine
    with that many misfires im sure i would notice
  1. fault codes?
    By farley2708 in forum Engine & Drivetrain
    Last Post: 5th February 2012, 00:18
  2. fault codes
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 31st January 2012, 19:02
  3. Fault Codes
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2010, 09:49
  4. Fault Codes
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 14:17
