Results 1 to 10 of 19
Thread: Removing dump valve (2.0 t)
    Jul 2011
    stockport
    Default Removing dump valve (2.0 t)
    Hi people, Im looking to sell my 2.0 turbo vectra soon, i've only owned it 3-4 months and it came with a dump valve so i've not got around to removing it yet. I think the dump valve will probably put most buyers off, plus its not to my taste anyway.
    Is there a replacment part that I need to fit or does it just pull off?
    Cheers, Liam.
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    depends what type of DV it is.. If its the type that bolts to the turbo in place of the factory wastegate then you will need to find another. if its the type that just fits in the vacuum pipes then just rejoin them or replace the pipe itself.. Got a pic?
    Regular Member rad9944's Avatar
    Feb 2012
    Buxted
    I will buy the valve off of you, I have been searching for one,
    I am here: [ame="http://maps.google.com/maps?ll=51.056802,0.160276"]Google Maps[/ame]
    Jul 2011
    stockport
    Quote Originally Posted by Caveman_nige View Post
    Heres a pic
    Jul 2011
    stockport
    Quote Originally Posted by rad9944 View Post
    I am here: Google Maps
    Ill pm you
    Jul 2011
    stockport
    Heres a pic of the dump valve
    Liam
    Jul 2011
    stockport
    Ive tried uploading a pic to this site but not having any luck, heres a link.
    http://s1080.photobucket.com/albums/...urrent=035.jpg
    cheers liam.
    Jul 2011
    stockport
    Infact its pretty obvious which one it is now , so I can buy that pipe from vauxhall?
    Thanks.
    Worksop
    Quote Originally Posted by liamgdr View Post
    Thanks.
    Just buy a stainless joiner same diameter as ur t piece only a few quid of ebay
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I've taken the dump valve off toay just to see 'if' it makes any noticable difference...problem i have is when I removed the valve(it was attached via a t piece in the main pipe at the front of the engine) it had a small bore tube attached to the top of the valve to a connection on the engine block,at the front..any idea as what i do with this open fitting??
  1. Dump valve
    By Chaly in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2013, 11:47
  2. vxr Dump Valve
    By leedslads in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2012, 22:01
  3. How much for dump valve on 09 VXR??
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2011, 22:25
  4. Dump valve
    By Martybhoy in forum The 'Off Topic' room
    Last Post: 7th July 2009, 11:38
  5. Replies: 23
    Last Post: 6th March 2009, 09:00
