Thread: limp mode
    Nov 2007
    lancashire
    Default limp mode
    19. cdti
    car is in limp mode fault code are as follows
    right here are the fault codes:
    P0100 - Intake Air Temperature Sensor Circuit High Input
    (54) - Present
    P0100 - Mass Or Volume Air Flow Circuit Malfunction
    (08) - Present
    P0100 - Intake Air Temperature Sensor Circuit Malfunction
    (21) - Present
    P0400 - Exhaust Gas Recirculation Circuit Low Voltage
    (02) - Present
    P1125 - Throttle Actuator Feedback Circuit Malfunction
    (08) - Present
    P0638 - Electronic Throttle Control Low Voltage
    (02) - Present
    any idears , these lead me to beleave wireing fault or ecu packed in but not sure were to start looking, checked fuses and block connecters and car is booked into auto elecs on thursday but would like to find myself first.
    birmingham
    Hi,had the same sort of problem myself with my dti,one of the codes po400 which is the EGR valve is i think connected to the other codes as if the EGR fails then other things related to the EGR wont function properly,in my car i took off the EGR valve cleaned it,put it back on and it was still the same,so i took it off again gave it another good clean and sprayed wd40(quite alot) onto the valve where the rod is and cleaned my inlet manifold,put it back together and problem was cured. Prior to this i changed the boost sensor,barometer sensor,air meter,pressure solonoids etc but made no difference. give it a try with wd40.ot might work.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Have you seen this site for code explanations http://www.obd-codes.com/p0100.
    I'd guess everything hinges around the MAF sensor but that's OMO .
    Nov 2007
    lancashire
    i have just replaced the egr with a new one and swapped maf with a known good unit from a friends car still the same faults!!
  1. Limp mode help
    By neill in forum Engine & Drivetrain
    Last Post: 20th March 2012, 19:53
  2. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
  3. Limp mode
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2008, 18:35
  4. Limp mode
    Last Post: 3rd July 2008, 10:34
  5. limp mode
    By vauxvec in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2008, 22:03
