Results 1 to 10 of 17
Thread: DPF/CAT - Strong Fumes Smell inside cabing - CDTI 150
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Default DPF/CAT - Strong Fumes Smell inside cabing - CDTI 150
    Folks,
    I need some help.
    My dads CDTI 150 SRI has got seriously strong fumes/smell inside the cabin. Stuck my head under the bonnet yesterday and rev'd the balls off it, there is smoke coming from the CAT area when its rev'd.
    We had it checked by a local garage who said that the DPF is blocked which has caused the CAT to burn out.
    Is there a way of unblocking the DPF without physically opening/removing?
    Also, im thinking about having it De-Cat'ed now, anything pointers, tips and ideas.
    Please help, this smell inside is so strong it catch's your throat!
    Thanks, G.
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    If you take it and thrash it it high revs down the motorway the higher gases and temp might help unblock it.
    I believe you can by stuff that you undo one of sensors and poor in and that aids unblocking and aswel stuff that can be put in fuel. How effective they are I don't no
    Birmingham
    Ill give it a thrashing today, bought some redex, might do it.
    wirral
    36 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Redex prob won't do anything mate tbh it's not to good.
    Forte is what the trade use a fuel cleaner. And they do dpf cleaner so might be worth trying that
    Birmingham
    I took it for a thrash anyway, to get rid of the cobwebs!! Then when I got back, I checked a post on this forum which tells you whcih code does and doesnt have a DPF, guess what, this one doesnt have a DPF, its got a code of 1.20.
    wirral
    36 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Haha sods law ay.
    Have you had a look to double check? You no what vxl are like
    have you tried tapping the cat listen if theirs anything loose in it?
    Sep 2011
    MILTON KEYNES
    9 times out of 10, smoke getting into the cabin on these vectras is a broken flexi. The flexi is right underneath the gear lever area, have the car running and have someone block the exhaust with their hand, while you look at the flexi....
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Dec 2011
    Seaham
    Tell them to hold a balled up rag on the exhaust end, you dont want to burn your mates hand!!
    Sep 2011
    MILTON KEYNES
    Quote Originally Posted by Ben50n View Post
  1. fumes inside car
    By neil52 in forum Engine & Drivetrain
    Last Post: 6th April 2013, 08:59
  2. strong smell of diesel
    By marky2027 in forum Vectra C / Signum Troubleshooting
    Last Post: 31st January 2012, 15:52
  3. Fumes inside car
    By lesron in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2011, 17:38
  4. Fumes smell in the cabin
    By Northy in forum Engine & Drivetrain
    Last Post: 17th January 2010, 19:59
  5. Strong Diesel Smell
    By DeathStar in forum Diesel Engine related
    Last Post: 2nd December 2007, 16:54
vectra deisel strong fumes
