Results 1 to 10 of 14
Thread: What's this pipe for ??
    Regular Member tosh23's Avatar
    HULL
    Default What's this pipe for ??
    Vectra 1.9 cdti 120 2007 manual
    On or near the bottom of the air box ( air filter housing) there is a pipe that is as thick as your thumb, The airbox has a hole on the bottom so it cant be a drain hole for water. I was just wondering what it was called and what does it do ? Thankyou Tosh
    HULL
    Ive found out that it is the PCV..Or crankcase pressure control valve..
    If Im understanding it right.....It takes the crankcase pressure made from worn rings or worn valve seats in the bore and pumps the oil misted pressurised air back into the airbox when the air intake needs clean dry air for the injection system...Another EGR, but this time..crankcase pressure recirculation...Is that right??
    Question 2..
    If the tube from the crankcase PC Valve that plugs into the airbox was disconnected from the airbox and allowed to just flop around what would that do to the smooth running of the engine...IF ANYTHING?...
    Thankyou for taking the time to read this....Tosh
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by tosh23 View Post
    Are you sure this pipe shouldn't be fitted into the hole in the airbox - I have the older 120 and the rubber hose which has an oval slightly elongated end pushes into this hole and has a groove moulded into it to hold it in place - its a right pig to get back in. I understood it was a drain in case any water or condensation should form in the filter airbox, although I have never looked to see where the other end goes! - Forgive me if I'm wrong - they may have changed it with the facelift.
    wirral
    42 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Sounds like the pipe thats for draining water from airbox
    Pcv( positive crankcase ventilation) is for emissions. As back in the old days crank case gases where vented to atmosphere. Now with tighter emissions control the gases are emitted back into intake to be re used.
    wirral
    42 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    wirral
    42 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    HULL
    Thank You very much for all your replies,
    I have looked at the air box and indeed there is a hole at the bottom of the box for water expellation
    It looks like it is a return for the crankcase breather into atmospheric pressure...
    I will endeavour to install said pipe back into its original home after all it cant do any harm.
    Im slowly and methodically going through the engine to find why my MPG is down to 33..(in town)
    I was going down the line of..a sensor that tells the ECU that the engine is cold which in turn makes the engine run rich ( possibly/ (choke like )).
    The thermostat is working within normal parameters
    With the car being an estate the regen comes on roughly every 200 miles..
    Which leads me to believe that the air/diesel mix is on the rich side and cokes up the exhaust ...
    Ohh well back to the drawing board...Once again thankyou to all for your ideas and replys....Tosh
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Have you tried the coolant temperature sensor. If this is reading low then the ECU could be fuelling for a cold engine.
    HULL
    Bingo..
    Many many thanks for that
    That is what I was looking for...
    Time to do some more research
    Once again...Thankyou.....Tosh
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by Critch View Post
    Ok Mate we get the point
  1. Brake servo pipe Help (Plastic Pipe)
    By Mark2.2 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2014, 15:41
  2. 2.2 dti - What is this pipe?
    By si_hoss in forum Engine & Drivetrain
    Last Post: 28th June 2011, 15:56
  3. pre cat de cat pipe
    By jay6392 in forum Tuning
    Last Post: 27th June 2011, 16:21
  4. need a new bit of pipe
    By Lump in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2009, 22:41
  5. all for a egr pipe
    By chrisgettings in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2008, 19:27
