Likes Likes:  2
Page 1 of 17 12311 ... LastLast
Results 1 to 10 of 161
Thread: Bad Cold Start Z1.9DT 120bhp Fault Fixed
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Default Bad Cold Start Z1.9DT 120bhp Fault Fixed
    Hi
    After struggling with a few cold starting z19dt's also a few Alfa Romeo JTD's with the same 8 valve engine.
    I found a cure for the famous cold starting issue, on this engine at least.
    The following conditions apply to this fault, if the engine wont fire first time:
    1. When attempting to start from cold the first time.
    2. When using multiple glow plug heat cycles.
    3. When using a battery booster pack/donor car (to ensure correct voltage on cranking)
    4. But will start after 5-10 seconds continuous cranking.
    5. But the engine always starts first time after initial bad starting success.
    If any or all of the above apply to your cold starting issues, then do the following only on a first time cold start cycle, do not do this if you have started the engine already.
    Make sure the ignition key is removed from the ignition, then remove the temperature sensor plug from the sensor on the thermostat housing located between the battery and right side of the engine, there's a black plug engaged into a green plastic housing on the sensor, pull up the yellow locking tab and gently lift the bottom black retaining lug and remove the connector from the sensor housing.
    Now turn on the ignition to cycle the glow pugs, the glow plug light might stay on longer than normal, let it fully cycle till the light goes off then start the engine,
    If the engine starts with a just few turns (better than the usual you have been experiencing) then turn off the engine, put the temperature sensor plug back on the sensor, now start the engine again and you will have the EML on with a fault code for the temp sensor.
    If the engine started ok and better than normal >> Replace the temperature sensor £8.60 from Vauxhall. Please use your chassis number when ordering the new sensor.
    Once you have replaced the sensor clear the fault code/s.
    I have done 6 of these faults over this cold spell, and been told by the owners that they have had various repairs done by main dealers costing hundreds and still have the fault, so go figure.
    Hope it helps any of you with this fault by looking at the search I did there's lots of owners with cold start problems on here and other forums.
    Have fun
    Nov 2010
    East Midlands
    Trim : design
    Hi, Thanks - That's interesting - have a 120 and I am in the habit of recycling the glowplugs at least a couple of times on a cold start and we have had a couple of -12's of late. It always starts but needs a bit more cranking if I only run the cycle once. I notice that the g/plug light does not seem to stay on long although I always thought that the plugs continued to operate even when the light had gone out. I have done all the usual suspects battery, glowplugs, and checked all connections,etc and it hasn't made a lot of difference. I was considering the starter motor but after reading your post may have a look at the sensor. Just a couple of questions
    1. I changed my thermostat a few months ago and obviously it came with a new sensor - I take it you can buy the sensor seperately from the thermostat
    2. When you change the sensor, do you drain the coolant or just remove it and put the new one straight in with just a minimal loss of coolant [if you are lucky]
    3. When the sensor is disconnected - what signal is sent to the ECU - is it saying that the coolant is very cold and therefore to operate the glowplug relay longer?
    Thanks again I'll give it a try
    Regular Member steve19cdti's Avatar
    Nov 2010
    s.wales.bridgend
    Quote Originally Posted by C-Owner View Post
    Hi
    Have fun
    ive had problem like this done as above didnt work mate changed loads off parts thinking it was them but no,till two wks ago car wouldnt star at all just click click from starter i changed the starter ,still same click click then changed battery more powerfull one started first time found out then the alternater was naft and battery (TOUCH WOOD THE CAR STARTS FIRST TIEME EVERY TIME HAVENT GOT TO WAIT FOR GLOW LIGHT TO GO OUT IN COLD MORNING MY OPPINION CHECK ALL THREE STARTER,ALTERNATER,BATTERY TOTALL COST FOR £357.99 FITTED MY SELF WELL WERTH IT LOL
    Regular Member Cruize's Avatar
    South East
    I'm half way through diagnosing this problem lol.
    I've bought new glow plugs and was just about to buy a new Thermostat unit. If its just the sensor then I'll go that way first.
    I dont know if its the sensor though as my heaters arent very good and when on full wack just blow mildly warm air. Which is making me think that the thermostat is stuck open? Would the sensor cause this issue too?
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by Cruize View Post
    I wouldn't have thought the thermostat would have caused you to have starting problems - it doesn't operate until the coolant starts to warm up - although it sounds as though yours does need replacing with the heating problems. Take it you have a 1.9 120/150 diesel - if so the thermostat has the new sensor already fitted so it could solve both problems by replacing it.
    May 2011
    South London
    Quote Originally Posted by steve19cdti View Post
    In your case number 3 applies as in the check list.
    May 2011
    South London
    Quote Originally Posted by alcutler View Post
    In your case number 2 applies you have to understand that its still not staring correctly after recycling the glow plugs then the advice stands.
    May 2011
    South London
    Go through the check list I made and please to all read carefully what I have posted, some of you seem to have speed read through it and not understood the conditions that temp sensor replacement is needed.
    As for actually replacing the sensor please refer to the manual.
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    The title should read 120ps not bhp, these cars are classed as 118bhp or did you speed read through that bit. lol
    A repeated glow plug cycle (Turning them off and on before ignition) just help to burn them out. Although it can high light a glow plug problem if you have one.
    I tell tale sign of glow plug failure is rough cold starting with whitish grey smoke that has a diesel smell to it. Once it's been running for a little while it goes normal as the engine block temp increases slightly.
    Wales
    Quote Originally Posted by DTI-Steve View Post
    Everone knows tham as 120bhp....
  1. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  2. cold start problems due to camshaft sensor fault ?
    By jaykay in forum Engine & Drivetrain
    Last Post: 15th June 2012, 19:05
  3. P0404 fault code & cold start issues
    By happyarthur1979 in forum Engine & Drivetrain
    Last Post: 24th January 2012, 16:55
  4. TCM fault ? Vectra C 03 Reg cold start problems
    By Agaspa in forum Engine & Drivetrain
    Last Post: 7th May 2010, 21:41
  5. 1.9 CDTi 120bhp hesitation FIXED :-)
    By sthomson1 in forum Engine & Drivetrain
    Last Post: 1st October 2009, 16:00
vectra c 120 fuel preaure switch
z19dt poor starting
vectra c 19 dt poor cold starting
does the temp sensor control heater plugs z19dth
vauxhall zafira 1.9 diesel slow to start
2008 vectra cdti 120 bhp trouble starting
vectra z19dt poor starting
vauxhall vectra 1.9 fuel pump relay inactive
astra 1.9 cdti poor starting
start problems with a 2009 vauxhall vectra cdti
coolant sensor vectra c 1.9cdti can it have an affect on starting
vauxhall 27 cdti wont start when temperature is minus
bad fuel pump astra 1.9
cdti 120 hard to start
poor cold start astra h 1.9 cdti
zafira 120 cdti hard start
vauxhall vectra c diesel engine start faults list
vectra c p0380 intermittent hard start
vauxhall insignia starting slow
z19dt coolant tempetature
astra 1.9 cdti poor starting starter motor
signum z1.9dt fuel injector synchronization
2009 vauxhall zafira b poor starting on cold days
starting problems on my vauxhall vectra 1.9 cdti
vauxhall astra h 1.9 cdti coolant temperature sensor
