Thread: plenum removal
    Regular Member fiend61's Avatar
    Nov 2011
    york
    Vehicle : vectra 2.8 turbo
    Trim : elite
    Engine : 2.8 turbo
    Angry plenum removal
    hi all
    went to do my thermostat today to find that one of the torq bolts that hold plenum on has a fubared head some gorilla must have been there before me has any one any tips so i can get the bolt out ???
    tia
    sorry 3.2 elite vec-c
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Hammer a smaller one on.
    On a normal socket. And then buy a new bolt for re fitting
    Nov 2011
    york
    Trim : elite
    Engine : 2.8 turbo
    errmm i meant a torq screw not bolt sorry
    Nov 2011
    york
    Trim : elite
    Engine : 2.8 turbo
    anybody??? getting desperate here vec bits all over the place
    South east
    Use a Dremel to cut a slot in the head and use a screwdriver to remove it.
    wirral
    39 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Aahh ok, am not sure if you can get it in a motor factors or not. But search for screw grab its pretty good stuff.
    May 2008
    Tyneside
    Could try this sort of thing http://www.ebay.co.uk/itm/IRWIN-5PC-...#ht_3239wt_952 I believe halfords do something similar for wheel nuts.
    Nov 2011
    york
    Trim : elite
    Engine : 2.8 turbo
    thanks for the replies but they are round head torq screws which access is down a 3" plastic tube !!!
    wirral
    39 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Search screw grab on YouTube an you'll see how good it is
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    can you not gently tap a slightly larger torx or even hexx/allen key into it?..im thinking of the ones that come in 'security' sets or as accessorries with socket sets etc..
  1. Advice sought - plenum/oil cooler on 3.2V6
    By MysteryElite in forum Engine & Drivetrain
    Last Post: 29th November 2011, 20:12
  2. Blocked breather? and excessive oil in plenum. 3.2 v6
    By Chuddy in forum Engine & Drivetrain
    Last Post: 12th March 2011, 21:43
  3. Plenum Chamber Removal Z32 v6
    By CDUB in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2008, 17:19
