Thread: Ncdc 2013
    Feb 2012
    Southampton
    Default Ncdc 2013
    Hi peeps. Probably been asked a million times, though I can't find it.
    If I brought a married ncdc2013 with colour screen but the seller didn't have radio code. Would it then be in "safe" mode when I fitted it?
    If so could I go in to the opcom infotainment section and retrieve or reprogramme the code?
    Very important question before I splash out on this unit.
    I take it by the way that it will be a straightforward fit into a 2003 pre facelift C
    will I have access to all the check controls that I don't get with my current tid.
    Lots of question but thanks for the answer
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    nope it wont be in safe mode mate i will go in no problems well aprts from the wireing u will need to do unless u already have a ncdc in your car
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    u will need the window switch plug for the map display mate and find the how 2 on here it show you how to do it i have done quite a few now
    Feb 2012
    Southampton
    Excuse me being thick. I've read the how to and can't figure out what door switch there is. I thought all the controls on the 2013 were on the rotary controls on the front or steering wheel?
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    its the to pin plug i think mate u get it from the scrap yard its the drivers window switch plug and u take it apart and put the correct pins in place and there should not be rotary controls in your car it should have 6 buttons
    Essex
    Quote Originally Posted by Shaun_inuk View Post
    If you have rotary controls on the steering wheel the NCDC will not be plug and play, married or not.
    NCDC for half can cars - buttons on the wheel
    CDXX full can bus - scroll wheels on the steering wheel
    Feb 2012
    Southampton
    Sorry. I meant rotary controls on the unit. I have got the 6 buttons on the steering wheel. Just can't understand why it needs wiring into the door?
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    No you need the plug that is used in the door wiring thats all.
    Feb 2011
    Selby
    There is a cable that you need but it's not available on it's own from Vauxhall. However one of the cables in the door is very similar and can be rewired to make an equivalent of the cable you need for the screen. This cable is available on it's own, or can be taken from any scrap Vectra C.
    Does that help clear up the confusion?
    Feb 2012
    Southampton
    Ah. Now that makes sense. Thank you
  1. ncdc 2013?
    By keith1983 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 12:42
  2. Ncdc 2013
    By jodiexii in forum Electrical & ICE (including SatNav)
    Last Post: 22nd August 2012, 12:27
  3. Any one got sat nav cd for NCDC 2013
    By driveryte in forum Electrical & ICE (including SatNav)
    Last Post: 6th July 2010, 18:36
  4. NCDC 2013 sat nav
    By Dwabo in forum Electrical & ICE (including SatNav)
    Last Post: 17th March 2008, 21:32
