Thread: New Wheels tyre pressure
    Regular Member Voxer's Avatar
    Ayrshire, Scotland
    Default New Wheels tyre pressure
    Hi guys,
    What's the best tyre pressure to use on 235/35/19inch wheels.
    Asked 2 lots of tyre fitters and the're not sure for the Veccie.
    Regular Member In a states's Avatar
    Dec 2005
    In an estate car
    Assuming you're a hatch/saloon
    Front 42
    Rear 38
    Straight from the manual.
    Regular Member VectraV6CDTi's Avatar
    Wilts
    When I got my car they had 31 in all round. I checked the handbook and they said 38 in the front for standard 17" (3.0 V6). So I put them up (did the back too) and since then the car seems a bit light on the front end and doesnt appear to grip as well.........is this a characteric of putting the pressure up that high?
    Ayrshire, Scotland
    Quote Originally Posted by In a states View Post
    Front 42
    Rear 38
    Hi m8, soz to pester, is those tyre pressures what you've got on yours, my manual for the GSI only tells me tyre pressures for 17inch tyres nothing above that.
    cheers
    Regular Member wardy's Avatar
    Chichester
    Quote Originally Posted by VectraV6CDTi View Post
    I aslso have the V6 (but pre-facelift). Putting the pressure up does lighten the steering & yes it does feel a little vague, but that was a common complaint of vecs. If you run them too soft (and IMO 31 is way too soft) you will wear out the tread towards the outside of the tyres i.e. they wont wear evenly.
    Dec 2005
    In an estate car
    Same size as VXR 19"s and that's what the manual says.
    Voxer you're asking about 19's not 17's.
    Regular Member Maddog1974's Avatar
    Jul 2006
    Colchester
    I checked mine for the 1st time since i bought the car 4ish months ago and my 235/35/19's were all at 25psi (must have been like that from new )
    Filled them up to 39 front & 35 back as manual says for a 2.2 with those wheels and f*ck me its a bumpy ride now. As i work near the stealers i popped in to check that was def right and the 'Technician' told me he sets them @ 32psi all round and the tyres will wear ok and its not to bumpy so thats my mission for tomorrow!
    Regular Member andy d's Avatar
    Feb 2006
    Inverkip
    I got a new set of hankook ventus sport on the front of mine to replace the goodyears, the handling was abismal, I then noticed the tyres were wearing a bit too much on the side of the tread.
    Checked the pressures 29psi as fitted by a local company (eejits)
    Put fronts to 38 and back to 36, handling a lot crisper now, the hankooks are actually quite good it's the fitters that were rubbish!
    Andy D
  1. tyre pressure.......?
    By david.aka.judas in forum Handling & Braking
    Last Post: 25th August 2009, 23:08
  2. tyre pressure for GSI
    By effone in forum Handling & Braking
    Last Post: 7th December 2008, 06:07
  3. Tyre pressure
    By vectra 120 in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2008, 20:53
  4. Tyre Pressure
    By PTC8 in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2007, 13:43
  5. tyre pressure
    By johnnyhg in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2006, 09:17
