Thread: Bad EGR and no response from the throttle 2,0 DTI
    Dec 2011
    Norway
    Default Bad EGR and no response from the throttle 2,0 DTI
    Guys,
    My 2004 2,0 DTI stops all the time. Spanner light comes on, engine is running but has no response from the throttle whatsoever. I turn the engine off for a moment, start it up and it works fine again.
    Had it at the local Vx dealer, they said bad EGR. They cleaned it and it worked fine for a week, then it was back stopping again. About 2 weeks after the workshop had it, I took out the EGR and it was pretty dirty already. I must assume that the workshop cleaned it nicely, which means it gets dirty pretty quickly. The first few days after I cleaned it it worked fine, then the problems started again. Do I need to replace the EGR, or is it something else causing the EGR to soot up quickly? Could the problem be somewhere else than the EGR?
    There seems to be no commons for when it stops. It happens with cold and hot engine, driving fast and slow, sometimes it's fine for a few days, other times it stops every 20 mins. My car has 168' kilometers on the clock.
    Any help appreciated, as I would really hate spending lots of money on an EGR that might not solve the problem...
    Cheers, Daniel
    Dec 2011
    Norway
    Forgot to mention that the engine often coughs a little around 2200 rpm, and the mpg seems to be lower than normal
    exeter
    check and clean the inlet http://www.vectra-c.com/forum/showthread.php?t=145119 .mine was doing what you said . i cleaned mine and then a week or 2 later it came back . someone said to look at this . so i cleaned it and 3 months on and still no light
    Dec 2011
    Norway
    Thanks, I'll give that a go
  1. Bad throttle response
    By Hodgy in forum Engine & Drivetrain
    Last Post: 6th February 2013, 19:21
  2. No throttle response Cdti 120
    By Vectra Meldrew in forum Engine & Drivetrain
    Last Post: 1st August 2012, 13:05
  3. intermittent throttle response
    By helisurf in forum Engine & Drivetrain
    Last Post: 21st December 2011, 22:06
  4. No throttle response on 3.0CDTi
    By Celes in forum Engine & Drivetrain
    Last Post: 26th July 2009, 10:35
  5. Throttle response
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 21st July 2009, 08:27
no throttle egr
vectra dti throtlle response cold
