Results 1 to 10 of 16
Thread: Can I change DMF and not the clutch
    Regular Member marky2027's Avatar
    Northumberland
    Default Can I change DMF and not the clutch
    If the DMF rattle has just started and I have no clutch slipping, clunking or start up issues can i just replace the DMF by itself. Really can't afford a clutch and only keeping the car another 6 months aswell
    Oct 2011
    Essex
    No. Factor in a starter too.
    exeter
    the clutch it only £100 on top of the price of fitting a dmf . it makes sense
    Northumberland
    The clutch kits are £200 plus. I could do without that but I suppose I won't know what's knackered until its all apart
    wirral
    58 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    You can yes but false economy not to change clutch aswel.
    As only be a few weeks/months till clutch goes aswel
    Northumberland
    Surely if you catch the failing DMF in time does this not stop the clutch failing? Why does the clutch fail too?
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by marky2027 View Post
    If the clutch components are ok and serviceable, can't see any problem with refitting them to a new DMF - I think the point some of the replies are making is that if you are stripping it down to replace the dmf you may as well replace the clutch components. If you are selling the car the extra cost of the clutch, while being a selling point, will not add to the value of the car and is dead money. Bit hard on the new owner - but hey that's life
    Jul 2009
    dudley
    Quote Originally Posted by Critch View Post
    true, i second this, you may get lucky and the clutch will last... but more than likely you will have to pay again for the clutch to be replaced before you sell the car... i had mine done in December, new slave cylinder, clutch assembly and dmf, it cost me £640 FROM A1 clutches, not original parts, but 12 months warranty and reputable by all accounts, it is the cheapest way i'm afraid... unless your doing it yourself and you can save £200 labour, i had my car back in 4 hours of dropping it off :-)
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    The clutches fail due to them being self adjusting and not being reset properly.
    Spend the extra £200 and save yourself the hastle, also means you'll have a new slave cylinder which can fail and need the gearbox removed to fix.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by andrew e View Post
    Do you mean a new starter motor - why would he want to replace that if its presumably working ok. Suppose he could consider replacing the engine as well.
  1. Dmf and clutch change
    By Signum150 in forum Engine & Drivetrain
    Last Post: 5th March 2012, 22:04
  2. change clutch as well
    By marko1973 in forum Engine & Drivetrain
    Last Post: 3rd January 2011, 23:46
  3. how do i change clutch on 2.0l dti
    By kez in forum Engine & Drivetrain
    Last Post: 20th May 2010, 19:51
  4. clutch fluid change
    By nikroc in forum Engine & Drivetrain
    Last Post: 16th November 2009, 23:44
  5. Clutch Change?
    By storey_3000 in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2006, 18:04
