Results 1 to 10 of 13
Thread: DIY remap 05 preface 1.9 cdti 120ps z19dt
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    Default DIY remap 05 preface 1.9 cdti 120ps z19dt
    I have my car remapped by myself and really feels good.
    The tooling involved are: WinOLS Demo and Ultraedit and Matlab and an DSP board (or any equivalent eeprom programmer)
    WinOLS for finding the map, Ultraedit for edit the mod, Matlab for calculation, DSP board is for programming the eeprom in ECU.
    What I did (in case you are interested):
    Switch off EGR in ECM and blank the EGR valve.
    Change the torque limiter (TL) to allow 360 NM between 2000-3000 RPM. This is equivalent to stock 150ps.
    Change the driver wish according to the TL
    Change the torque to injection quantity (IQ) conversion map to allow 400 NM input
    Change the IQ limiter by RPM and by temperature. To ensure the torque are not limited until 90 degrees.
    Change the rail pressure for better timing. (SOI is stock to avoid damage)
    Calculate the expected MAF and AFR by using rail pressure map, boost pressure map, IQ map and TL map.
    Optimised the Lambda map (Smoke limiter map) according to expected MAF and AFR to avoid this map from limiting the IQ, and to minimise the smoke.
    Get the car logged today, drives good, smooth and can feel much powerful, have a friend following me, reported with no smoke. The instant MPG rised about 4-8 for a known road. Will report real MPG increase.
    Will use a can-bus flasher later, because it's really a hell to take ECM off (i only loose the upper bolt ECM plastic bracket and take it off by applying force...).
    Jul 2010
    Scotland
    Some interesting graphs:
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    Nice presentation you have there . Are you going to have rr - test to se the results?
    Can DSP board program via OBD?
    Btw, my z19dt pulls 170 hp / 400 nm.
    Regular Member coldo's Avatar
    Scotland
    That's very impressive work. Well done you mate for working this out.
    Jul 2010
    Scotland
    Quote Originally Posted by zafira View Post
    No, the DSP board is just a generic DSP, it have the capability to talk to OBD but no time to figure it out.
    170 is not a problem if raced the turbo and rail pressure, but bear in mind that i am on stock turbo, stock DMF, stock clutch, stock air filter (All standard for a poor man lol).....
    AND PS: no extra £ for RR lol
    Sep 2011
    Kent
    all very impressive if completly over my head
    Aug 2010
    North of Norway
    Quote Originally Posted by yysnet View Post
    But what tool did you use to write the map in to ecu?
    I use stock turbo and boost 1,56 bar up to 2800 rpm and 1,64 further. Rail pressure its 1700 bar at max. I have also de-cat/dpf to get flow. Egr is shut down to ca 10 % (i got eml with less) and injector time are changed. The is like new, with + 400 nm between 2100 - 2800 rpm.
    Aug 2010
    North of Norway
    I use stock turbo and boost 1,56 bar up to 2800 rpm and 1,64 further. Rail pressure its 1700 bar at max. I have also de-cat/dpf to get flow. Egr is shut down to ca 10 % (i got eml with less) and injector time are changed. The car is like totaly another with + 400 nm between 2100 - 2800 rpm.
    Jul 2010
    Scotland
    I got egr removed from map. Currently I am remap by removing the ECM and write the EEPROM by my home brew tool. Later will become a can bus flasher.
    I don't set the soi until I got a cylinder pressure sensor, to avoid a big bill from my pocket. I guess in cold Norway you could have -3cad without problem?
    Jul 2010
    Scotland
    Just to report that the engine defo runs better, easy start, faster response to pedal, pulls faster, and the most important, MPG rise about from 48 to about 53 in an A road ave speed 50mph, outside 5deg, heater on.
  1. 1.9 cdti 120ps picture?
    By Flyingdutchman in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2009, 18:09
  2. location and removal of a cdti sxi 120ps ecu
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2008, 19:08
  3. cdti sxi 120ps remap???
    By big rich in forum Diesel Engine related
    Last Post: 17th November 2008, 05:56
  4. cdti sxi 120ps air mass question
    By big rich in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2008, 12:49
  5. caterman tuning cdti 120ps
    By tash in forum Parts for sale
    Last Post: 12th July 2007, 19:09
z19dt remap
z19dt remapping
vectra 1.9 cdti 120 remap
vectra c 1.9 cdti diy increase powerremap online z19dtkess v2 titanium opel 1.9 cdtiz19dt max boostz19dt map filesz19dt remap files downloadz19dt timing marksz19dt remap filesastra cdti 1.9 8v ecm titamiumkess opel astra 1.9cdti signum cdti 150 eml filez19dt diy remapz19dt limiter removalz19dt 120 ps gearingsignum 1.9cdti 120 remap19 cdti cold boost limitvectra c 1.9 cdti 120 remapvectra c diy remap1.9cdti 120 rema0signum 120 remap filevectra c cdti modswinols for vauxhall z19dt
