Hi Mick,
Yeah, it's relatively simple to do, although you have to remove the seat from the car to do it.
Two large Torx bolts behind the seat on the runners and another one on the end of the seat belt by the door and then unplug the multi-plug under neath and the seat lifts out.
Stripping the seat is fiddly and a bit time consuming, but easy enough to do, from memory (and this is from memory so may not be perfect).
Underneath at the back, unclip the two hooks at the end of the elastic for the back (you'll see what I mean when you look at it).
Slide your hand up BEHIND the back panel almost to the top and you'll feel a plastic piece that goes horizontally across the full width of the panel that's hooked over metal, unhook it (push up and out hard from inside) and then the panel just slides out downwards.
It's easier to remove the base first as that gives you better access to the back, but you may get away with not doing it. Remove the adjuster handles and side winder handle (you'll need two or three different Torx bits for this).
At the back of the base underneath you'll see a plastic rod threaded through the fabric with hooks on it, unhook them then look round the outside edgs and you'll see the same type of plastic full length clips underneath that held the back on, undo them all and the base pretty much just lifts off.
Then in the back, working from behind, push the seat springs in hard and you'll see either two or three bolts (varies) holding the air bag in place, undo them (careful you dont lose the nuts), carefully unclip the electrical connector to the airbag and pop it out and remove the airbag.
Remove the head-rest.
Stick your hand up inside the top of the seat and you'll feel the plastic "pipes" that the headrest sits in, each one has a clip at the bottom, push it in and the whole fitting should slide out.
The rest is fairly self explanatory, you'll see it all as you go along.
Removing the fabric from the cushioning is very fiddly, Vauxhall use a lot of metal rings to hold the fabric in place and you need to either open these up using pliers one by one or cut them with a strong pair of cutters (when you put new cloth back on just use strong cable ties in their place).
Hopefully this combined with the pics in my stripping the leather seats thread (
http://www.vectra-c.com/forum/showthread.php?t=148142) should make sense, give me a shout if you're still confused.
If you get really stuck and can drive down to Ely with the new seat covers/seat then I'd be happy to give you a hand (but pick a warmer weekend
Ian
