Results 1 to 10 of 13
Thread: Bio-Diesel....would you ???
    The Blackburn End
    Question Bio-Diesel....would you ???
    A quick and simple question.
    If bio-diesel was proven to be safe, a few pence cheaper and easily available, would you use it ?????
    Yes or No ?
    Belfast
    i wouldnt no !!
    Regular Member The Doc's Avatar
    'Norf Yorks.
    No. My fuel pump runs higher pressures than standard.
    South Central England
    8 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I have use veg oil in my last DTI but I don't know about this one. Are we talking about from a pump or in your garage?
    The Blackburn End
    Quote Originally Posted by nutron View Post
    I Are we talking about from a pump or in your garage?
    Pump
    The Blackburn End
    Quote Originally Posted by CDTi View Post
    I've been told by an expert in the field that high pressure's are not a problem.
    However, in the real world if your blowing megabucks on a high performance diesel car, your not the type of person to change to risk 10p-20p/litre saving.
    Regular Member Ross DTi 2.2's Avatar
    Münster, NRW, Germany
    Commercially produced bio-diesel is better than mineral diesel. It burns cleaner and has a higher cetane level than standard diesel, therefore your performance will improve.
    It doesn't matter what sort of fuel pressure your car is running.
    'Norf Yorks.
    Interesting though I would need more facts and proven figures etc.
    Regular Member G.O'Rilla's Avatar
    Jul 2006
    On the road
    Commercially produced biodiesel is only 20% biodiesel - greater quantities of this cause problems - see other threads and URL links on the subject (www.biodiesel.org) . Ordinary pump diesel according to EN590 spec (I was looking at it today when putting a tender together) has a maximum of 5% FAME - which is the Bio bit.
    To answer the question - the manufacturers spend a fortune in making their diesel engines work well with commercial spec fuels, so why use anything else? The diesel engines for european spec cars are optimised for EN590 diesel (bio or not) so that is what I would use. Even though my car is leased, it gets the fuel for which it was designed and not some recycled chip fat.
    You pays yer money and you takes yer choice
    Here, there and every where!
    Found some useful information HERE
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. V POWER DIESEL Vs DIESEL
    By OSSY in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2009, 21:22
  3. BP Ultimate Diesel vs Morrison's mucky Diesel
    By Big Knox in forum General Chat
    Last Post: 31st March 2009, 13:11
  4. Shell Diesel Extra Or BP Ultimax Diesel
    By tonyx420 in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2007, 13:25
  5. 2.0 Diesel
    By cp123 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2006, 23:50
