Thread: Do these symptoms sound like an injector problem ?
    North west
    Default Do these symptoms sound like an injector problem ?
    I have just had my 1.9 cdti (150) in at Vx for the second day running to try and diagnose a problem. When it had the diagnostic check it came back as the EGR valve (9 months old), they checked all this today and now say its not the EGR valve but think there is a problem with the Injectors.
    The car is juddering, around the 1500rpm - 2200rpm point in all gears. There doesnt seem to be a loss of power outside of this range, and runs fine then too... ? If I wanted to 'thrash' the car so to speak it would run fine ??
    I am reluctant to have Vx send it away for the Injectors to be tested as I havent got the money to just throw around while they are 'guessing'.... What other possible causes could it be ? Any ideas ??
    Thanks...
    Northampton
    Engine : A20DTH
    Mileage : 88000
    what colour are the injector plugs blue or yellow?
    North west
    They are the blue one's, these were also done last year.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    For starters before going anywhere near injectors, check the vacuum pipes. If split they are known to cause problems in this range as they affect tubocharger spooling. Fail in that I would say EGR valve. Only plump for injectors as a very last resort. Also ask why they think that. If they are basing their diagnosis on what diagnostic software tells them then that's not the most accurate. To understand how the injectors are performing they need to do a leak off test.
    North west
    Thanks. I might ask my local mechanic to check the vacuum pipes before Vx take it on Monday. I have a vision that it comes back with the same prpblem but with a 300 quid bill just for 'checking'...
  1. Injector Problem
    By vectra19 in forum General Motoring Chat
    Last Post: 8th June 2012, 23:40
  2. 150 injector problem
    By lee640 in forum Engine & Drivetrain
    Last Post: 13th January 2012, 21:13
  3. Does this sound like the 3rd Injector Problem??
    By MT82LFC in forum Engine & Drivetrain
    Last Post: 23rd May 2011, 22:03
  4. 3rd injector problem
    By smurfy in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2009, 16:56
  5. EGR or INJECTOR PROBLEM
    By dingle in forum Engine & Drivetrain
    Last Post: 18th May 2008, 16:56
Vauxhall Vectra c 2008 injector symptoms www.vectra-c.com
1.9 cdti 3rd injector issues and symptoms
vectra 1.9 cdti injector sound
a20 dth injector problem
