Thread: windscreen wipers went NUTS!
    Regular Member twinxster's Avatar
    Jan 2012
    north wales
    Vehicle : vauxhall signum
    Trim : design
    Engine : 1,9 cdti 150
    Default windscreen wipers went NUTS!
    Hi all, on the way home tonight in the pouring rain, something very strange happened. I had my wipers on full pelt, and next thing... both wipers clashed together, with one pulling the other one way and vice versa. I stopped the car, and they were a state. I managed to clip the drivers side wiper back on, and the passenger one looked ok. But when i put the wipers back on, only the drivers side works? When i tried moving the passenger side wiper manually, it actually moves. But the drivers side is stiff(as it should, i take) Is the solution for this problem going to be costly?? And is there a seperate motor for each wiper??? This is my 5th problem now since buying the car just over a month ago. And im starting to lose faith in her.
    Sounds like the linkage has gone. Search on here there ate lots of cheap solutions.
    New Member melvyn8181's Avatar
    Jul 2011
    north lincolnshire
    get a second hand linkage/motor from breakers £30 ish. easist way i reckon
    Jan 2012
    north wales
    Trim : design
    Didnt get home untill an hour ago. So couldnt inspect the damage. I had a search on the forum, but couldnt find anything. Ill put in linkage in my search.
    Is there a seperate motor??? As my driver side wiper is working fine. Im hoping its the linkage arm
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    Have a look at this, many of us have suffered the same problem & this is the cheapest way of fixing it.
    http://www.vectra-c.com/forum/showth...t=wiper+repair
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
  1. Windscreen wipers
    By Ziggy in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2012, 18:31
  2. windscreen wipers
    By Lee.J in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2012, 23:26
  3. Windscreen Wipers
    By topman in forum Vectra C / Signum Troubleshooting
    Last Post: 24th January 2009, 20:30
  4. Windscreen wipers
    By Q22ube in forum Engine & Drivetrain
    Last Post: 10th December 2008, 21:11
  5. windscreen wipers
    By jamesr in forum Bodywork & Interior
    Last Post: 1st January 2007, 11:10
