Thread: dump valve for 1.9cdti
    Feb 2012
    glasgow
    Thumbs up dump valve for 1.9cdti
    was looking for a dump valve for my vectra c 1.9cdti has any one got any ideas on wat kind of dump valve i would need
    Regular Member UltraVec's Avatar
    Jun 2011
    Dublin
    No point on a diesel man, can actually do more bad than good.
    I'm sure more people will let ya know why.
    Feb 2012
    Dover
    Dump valves sound ****ty on a disiesel.
    Had one on an old leon fr. Sounded awful.
    clatter clatter clatter fwoooooo....clatter clatter clatter.
    Sounds just like someone blowing through a digeredoo but not knowing how to use it.
    Jun 2011
    Dublin
    If your looking for a better or more powerful sound then fit a proper induction system or cone filter, turbo will spool up a bit quicker and the sound from it will certainly turn heads on lift off!
    South Central England
    10 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Dump valves on a diesel would sound just like on a petrol, obviously a duff kit you had. I fitted an electrically control dump valve once and it made a very loud hiss, exactly as I have heared from petrol versions. It would need to be electrically controlled, a microswitch on the clutch would be best but it would not benifit you in terms of performance. If it were to open at the wrong time it could do damage to the turbo but the ECU should detect a boost leak and go into limp mode, so the chances of damage are tiny. In combination with an anti lag system fitted to the vacuum actuator, a dump valve on a diesel would be very effective at reducing lag when changing gear.
    Regular Member nath-lav's Avatar
    Mar 2011
    newcastle upon tyne
    iv got one on my 1.9 cdti 150 along with k&n panel filter airboxmod and remap and a love it
    Mar 2011
    newcastle upon tyne
    Mar 2011
    newcastle upon tyne
  1. Dump Valve
    By smartie1986 in forum Diesel Engine related
    Last Post: 14th September 2011, 08:38
  2. dump valve?
    By stanlee in forum Diesel Engine related
    Last Post: 27th January 2011, 17:04
  3. Dump valve on 2.0T
    By ROCKATANSKY in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2010, 01:54
  4. Replies: 23
    Last Post: 6th March 2009, 09:00
  5. 1.9cdti With a dump-valve????????
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 12th September 2008, 16:59
