Thread: Timing belt
    Mar 2011
    newcastle upon tyne
    Default Timing belt
    Got a vectra c 57 plate with 53000 miles on it,should i get the timing belt changed now or is it to soon?would rather change it earlier rather than later,heard some horror stories of belt snaping and then costing big money to fix the engine.
    Thanks in advance guys.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Won't do any harm getting it done now for peace of mind
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Personally I'd get it done. It's 5 years old now (if original belt). Get the water pump done too
    Not worth the risk of it snapping, which is usually caused by the water pump seizing.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Change the water pump too, these seem to be the main cause of belt failures.
    Mar 2011
    newcastle upon tyne
    Ok thanks,should i take it to the main dealer which will prob be expensive or will a local garage be ok with the job? if so anyone around the newcastle upon tyne area know any good garage`s that will do the job ok
    Thanks again in advance.
    11 Post(s)
    Quote Originally Posted by don1966 View Post
    Got a vectra c 57 plate with 53000 miles on it,should i get the timing belt changed now or is it to soon?.
    And the engine is?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Profile says 1.9 Cdti 150
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Where in Newcastle are you mate? Know a couple of good independent garages I could recommend
    ---Sent from my iPhone 4 using Tapatalk
    Mar 2011
    newcastle upon tyne
    Sorry car is 1.9 cdti 150.
    I`m in whitleybay but work in Newcastle city so either coast area or newcastle.Thanks.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 137000
    Personally I'd get it done. Change the water pump too, mines on 62000 miles now. and i believe my water pump has seized a few days ago ive had a burning rubber smell from the cam belt area so i would definitely get it done i will keep you updated when i take the cambelt cover off to inspect it
    1.8ls
  1. anyway to do the timing belt without timing tool
    Last Post: 15th December 2012, 18:47
  2. Timing belt
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2012, 11:21
  3. Timing Belt
    By rmg1 in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2012, 06:52
  4. timing belt?
    By leonvectrac in forum Engine & Drivetrain
    Last Post: 28th April 2011, 19:02
  5. timing belt?
    By jaff in forum General Chat
    Last Post: 4th September 2008, 20:15
vectra c 1.9cdti 16v timing belt tool site:www.vectra-c.com
