Thread: Heater issue
    Regular Member Tinks's Avatar
    Jan 2012
    Whittlesey
    Vehicle : Vectra C Elegance
    Engine : 1800
    Mileage : Lots
    Default Heater issue
    Hi all,
    The Vec is legal at last!! I have the usual problem of the blowers only working on number 4 - this isnt the major issue - when the engine has heat in it and the fan is put on it blows warm/hot air, this is normal, but after a 20 seconds or so the temp drops to its lowest on the gauge and blows out cold air.
    Is this normal or is there another problem.
    Tony
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Thermostat faulty?
    ---Sent from my iPhone 4 using Tapatalk
    Jan 2012
    Whittlesey
    Engine : 1800
    Mileage : Lots
    Hi Tony, thats pretty much what I was thinking, just never seen the temp gauge drop so quick.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    If you're only indling, or driving around town this is probably normal. If you're cruising down the motorway, then prob not normal.
    Get the fan sorted (probably the resistor pack) and see if it does the same on number 2.
    Nov 2011
    Teesside
    Default Mine too
    I have a similar issue too with my Thermostat. When the car is stood still, the temp gague rises to mid point and blows hot air. As soon as I start to drive, it rappidly cools to zero on the temp gague and only blows nearly cold air. It has been suggested to me that the Thermostat is stuck open and allowing the coolant to circulate the engine when it shouldn't be. New thermo from VX is £50 inc. VAT. My mums bf and I are gonna have a go at replacing mine soon. I don't know much about cars lol.
  1. Heater Blower Issue - Only works on Position 4
    By phughes64 in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2015, 21:09
  2. Irratic Heater Issue
    By Topbeats in forum Vectra C / Signum Troubleshooting
    Last Post: 18th May 2013, 10:47
  3. Issue with replacing broken heater control
    By Trantor in forum Bodywork & Interior
    Last Post: 18th June 2012, 21:46
  4. Heater Blower Issue - Only works on Position 4
    By phughes64 in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2012, 20:47
  5. Heater/Blower Issue... Relay problem with PICS!
    By lew1984 in forum Vectra C / Signum Troubleshooting
    Last Post: 13th August 2011, 18:24
