Results 1 to 3 of 3
Thread: 2005 upper, outer, rear suspension rose bush
    Feb 2012
    bristol
    rolleyes 2005 upper, outer, rear suspension rose bush
    Hi All,
    Like many vectra owners I need to replace the outer upper rose suspension bushes from the banana arm on a vectra C 2005. I can get the bushes or the whole arms for a reasonable cost. Looking at the job, it appears easier to change the outer bushes without removing the banana arm. It seems I need to do a fair bit of dismantling if I want to change the whole arm. Has anyone done this job themselves? (please only respond if you have personally got your hands dirty doing this). I'm wondering if it is possible to change the banana without partially dropping the rear subframe? If it is necessary to remove the subframe then I would like to change the bushes in situ. Does anyone know if the vectra B bush removal tools are suitable?
    Thanks in advance for your advice.
    Keith
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    access is a little tight but no need at all to partially or fully drop the rear subframe. At a nice pace allow 1 hour per side.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Only think I dropped was my exhaust just to allow me some room to get in an "crack" the nut off.
  1. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  2. Replace Outer Bush on Rear Upper Control Arms Easilly
    By Rebellion in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2012, 06:43
  3. rear rose bush
    By greenstreet in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2010, 18:16
