Thread: Updated speedo-how to clear error codes ?
    Regular Member Fash's Avatar
    Doncaster
    Default Updated speedo-how to clear error codes ?
    Just updated the speedo in my 2.2 elegance to a nice SRI one. Mileage is pretty much the same so I was quite happy with it. However...according to the speedo there is a fault with my xenon lights self leveling system...
    As my car doesnt have them I presume this error was stored on the previous speedo (as was the service indicator that I have managed to clear)...
    How can I clear off this xenon lights error ? Will it go after 40 or so starts, or do I need to remove the battery for an hour or so ?
    I also have the eml on, however I have removed the egr and blanked that prior to getting an egr cheater for it in due course
    PS If this is in wrong section can a mod move it please ?
    Administrator plasma's Avatar
    On the Forum
    369 Post(s)
    Engine : 150
    Mileage : 74000
    the clocks will need to be told via tech2 that it doesnt have xenons. I hope u bought it tech2 cleared or at least have the code for it.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Easiest thing to do is take both apart and use the circuit board from your old one with the front and needles of the Sri one. Did the same when I upgraded my old saloon sxi dash. The system then thinks nothing has changed.
    Doncaster
    Quote Originally Posted by Ian-Highlander View Post
    I suppose thats what I need to do then-how easy is that to do??
    Doncaster
    Quote Originally Posted by plasma View Post
    Nope it was an ebay purchase which didnt specify about fault codes being cleared
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    its not a fault.. its a programming issue as the clocks need to be told it hasnt xenon.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by Fash View Post
    If your EGR was working before you got rid of it, just plug it back into the loom and secure it somewhere, this will sort any warning lights and still keeps the EGR blanked, this is mine. The plunger must be able to move freely hence why mines mounted to the side.
  1. error codes
    By bellstephen in forum Vectra C / Signum Troubleshooting
    Last Post: 21st February 2012, 17:16
  2. Clear speedo needles
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2011, 20:40
  3. error codes
    By delboy2028 in forum Engine & Drivetrain
    Last Post: 29th June 2010, 13:27
  4. Hello All..... I'm after your help (ERROR CODES)!!!
    By albertoleach in forum Introduce yourself.
    Last Post: 9th March 2009, 09:50
  5. error codes
    By pipamish in forum Engine & Drivetrain
    Last Post: 28th May 2008, 08:03
