Results 1 to 10 of 19
Thread: Pointless garage accreditation scheme
    Regular Member clightowler's Avatar
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    Default Pointless garage accreditation scheme
    Hi All,
    Just been speaking to a garage in Leeds (wont give name but they have a couple of garages, one in Halton near Matalan and one in Harehills so locals will know who I mean) who are apparently accredited with Bosch, OFT and ATA.
    Wanted quote to replace inlet manifold on cdti150 telling him the Swirl valves were shot. came back to me with the sucking of air telling me its a difficult job at least 5-6 hours so was gonna cost £700 to supply and fit!
    after getting back up i asked if that was including all parts, gaskets, motor manifold etc and was surprised that a garage with all these accreditations came back and said it was manifold and gasket only and seemed surprised when I mentioned it!!
    So not only are they overquoting time to complete and charging extra Labour but they appear to be incompetent by not following the requirement as stated by VX, Pierburg, SAAB and FIAT regarding the motor he didnt even try to charge me it as an add on he was just unaware of it. had I been a normal Joe and trusted them I would have been ripped off massively!!! Shame as they used to be a good garage.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Doesn't need to be whole garage for them accreditations
    Can be 1 technician in their.
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    thats what makes it a pointless scheme, am so glad I dont need to use garages for most things.
    Have you tried changing the inlet manifold? Took me about that length of time. There's also no need to change the swirl actuator unless it's not working, and the only parts it actually consists of are the manifold and gasket - there's nothing else that actually needs changing.
    Why not try it yourself and see how you get on...?
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    21 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 221,007
    To be fair, they do indeed sound like an utterly pointless garage. There seem to be a lot of these 'sharp operators' about - and not just in the garage business. There are scammers EVERYWHERE.
    Get some alternative quotations elsewhere and don't forget to wave your friendly garage goodbye, if you know what I mean , as you make for the exit.
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    Quote Originally Posted by Penfold101 View Post
    I would expect 5 hours or so for myself too, but that would include getting tools out of shed etc and doing it in the street. they are a "professional" garage. TIS quotes 3.4hrs incidentally just had a quote from Bankside Garage, who said its 4hrs labour (£180) + parts (£227 manifold + 130 Motor + bits) slight difference dont you think?
    As for the motor argument, firstly they are a professional garage charging to perform a task, as such they are obliged to at the very least inform you of what the manufacturer states needs doing in relation to that task. with the option to pay extra, just like timing belt changes, pollen filters etc. Unfortunately he was totally oblivious to the requirement.
    Have looked into this a bit and the reason you change appears to be because it learns the range of movement from fully closed to fully open on the valves on the first power up This looks to be slightly different on each manifold (manufacturing tolerances and the valves have been re-designed anyway) which could result in the valves either not fully closing or not fully opening. Some get away with it and dont notice a difference, others dont and as it would need fitting to a new manifold anyway and the job to fit/chnge later is it worth not doing it?
    Quote Originally Posted by clightowler View Post
    I'll agree a garage would be a lot quicker than me doing it, and in fact I'D be a lot quicker next time due to having a better idea what I'm doing. While I agree with you that the garage is certainly not a perfect example, I just took offence to the OP blasting a garage for giving him a quote for a job which he has no experience of doing himself. Luckily he has a choice and doesn't have to go there...
    As regards the motor, that was new to me there mate. Whether it learns or not I've no idea - seems a little complicated to me for what is simply a motor that moves one way or the other but I've never really looked into it. The fact that it can be changed separately from the manifold anyway meant I had no reason to replace it at an extra £100 quid, and have never had any issues since. In my eyes any garage insisting on it being changed too is just out to make a quick buck...
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    have got to admit, I cannot see why Pierburg designed it as a "once only" learn, as you say if the motor itself works why can it not be reset to go with a new manifold, tho if Tech 2 was needed to do it by the time the stealers have added the extra hour labour to do it etc it would cost the same.!!
    as for the original post, I wouldnt have criticised a garage for a job that I couldnt do myself, unfortunately only reason I am looking at a garage is because I dont have anywhere indoors to do it myself and dont want to contaminate fuel post filter by trying it outdoors in winter and weather stopping play I am still hoping I can keep it running till the weather improves and I will do it myself. Personally I think that the first garage are using an old Autodata or TIS record which states that the timing belt needs removing. Either that or a Haynes manual off the shelf lol.
    Don't knock it - I used the Haynes manual and the How2 on here when i did mine, but you're right that the timing belt doesn't need removing. Did you watch the video I did mate...?
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    had mine done under a private warranty the quoted bill was 600 odd quid.
    had to wait an extra day aswell as some sort of special tool was required at some point (dont know if this is true)
    think its a good 5 hour job though
  1. has anyone got one of these or are they pointless
    By paullivi in forum Petrol Engine related
    Last Post: 12th January 2013, 22:52
  2. Another Pointless Led Mod,
    By ScotsDragon in forum Styling
    Last Post: 13th May 2012, 10:13
  3. pointless but fun lol
    By paulvectrac in forum Diesel Engine related
    Last Post: 24th October 2010, 20:23
  4. Pointless fact!!!!!
    By stu28375 in forum The 'Off Topic' room
    Last Post: 4th August 2008, 15:14
  5. Mrs D's pointless facts.............
    By Mrs D in forum Comedy & Humour
    Last Post: 13th October 2005, 00:19
