Results 1 to 3 of 3
Thread: Injector Readings
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Default Injector Readings
    Someone (I've never met) came around and used some software (no idea what it was) on a friends car and got the following readings:
    cylinder 1 -4.68
    cylinder 2 2.71
    cylinder 3 5.07
    cylinder 4 -3.24
    Anyone any ideas if these are looking slightly incorrect??
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    They are out m8, -3/+3 is the norm. Have you changed the injector plugs been changed? Then again I would get a leak off test done to confirm as the diagnostic results aren't the most reliable.
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    LOL, have seen this and very curious about the answer. These numbers will "roll" by time, i.e. some number will become positive whilst the remaining become negative...
    As GazCDTI150 mentioned I also found out that the readouts are rubbish and some value are incorrect.
  1. Replies: 15
    Last Post: 27th September 2013, 00:22
  2. Can anyone help with these readings?
    By Lozza in forum Engine & Drivetrain
    Last Post: 8th August 2012, 21:52
  3. Injector Wiring Loom (common fault on 3rd injector)
    Last Post: 8th October 2010, 12:18
