Thanks Thanks:  1
Thread: CDTI Fuel filter removal tool
    Regular Member v33tra's Avatar
    ayrshire,scotland
    Default CDTI Fuel filter removal tool
    Just thought i would pass this bit of info onto other CDTI owners
    While searching for a fuel filter removal tool i came across several ranging from £38 up to and over £70 then i came across this little beauty made by Blue Print for £22.99 plus postage and if anyone like myself has had the pleasure of changing one of these filters without the right tool you will know it can be a right pain to do and can break or crack the expensive filter housing if done incorrectly therefore i thought it was time to invest in a proper tool instead of using filter straps etc
    Anyway here`s the link to the one i bought once it arrives i have 2 cdti Vectra`s awaiting fuel filter changes so i will let you know how these perform and maybe even a wee how 2 with photos
    It requires a vice for use though so if you havn`t got one then it`s probably useless
    http://www.ebay.co.uk/itm/1507536564...84.m1497.l2649
    Hope this helps someone
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    Not sure if you'll need this for the V6 CDTI as it's on a torx screw. It's an easy task without any special tools.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Yep definatly don't need it for v6. I've changed mine loads just torx bit and small flat blade screwdriver is all that's needed.
    O and I use a syringe to put fill filter to the brim to aid in starting
    ayrshire,scotland
    Sorry i should have been more specific in the title it`s for the 1.9`s and yes the filter can be removed without this tool but it runs a higher risk of damaging the plastic casing
    I was only trying to help but if it`s not for you then fair enough it`s only a suggestion take it or leave it
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by v33tra View Post
    Just didn't want anyone else to get confused mate. Everyone on here loves a bargain tool or 2
  6. Thanks afcmc1 thanked for this post
  7. #6
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Fair enough was more so if anyone new to the v6 new they didn't need the tool.
    As for the 1.9 itl prob make life a lot easier.
    So good find
  8. #7
    Regular Member CH-VECTRA-ELITE's Avatar
    Frimley
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 140000
    If you could do a how 2 that would be great, i've just paid vauxhall to replace mine when it went in for a service but would like to know how its done
  9. #8
    Nov 2010
    East Midlands
    Trim : design
    Thanks for that - looks a handy bit of kit - when I did mine last time I managed to hold the bottom half gently in a vice, and then used one of those rubber grip straps and undid it. I put copper grease on the thread so hopefully it will be easier next time. The other thing to watch are the connections where the fuel pipes push fit into the lid - they are easily damaged where the pipes clip into the housing.
    Would be a lot simpler unscrewing the top with this tool.
  1. Fuel Filter Removal
    By andsaw in forum Engine & Drivetrain
    Last Post: 5th January 2013, 21:00
  2. Diesel Filter Line Removal Tool
    By jatint in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2011, 17:25
  3. Whats the Tool for Fuel filter ??
    By dv8 in forum Vectra C / Signum Car Chat
    Last Post: 19th September 2010, 21:14
  4. special tool for diesel fuel filter removal?
    By spartan80 in forum Engine & Drivetrain
    Last Post: 31st October 2007, 18:26
vectra v6 cdti fuel filter tool
vectra c cdti fuel filter housing tool
how to make a diesel filter removal tool
Vectra C fuel filter tool
