Results 1 to 10 of 13
Thread: Heater blows cold when idling
    Regular Member manimal's Avatar
    Grimsby uk
    Default Heater blows cold when idling
    Hi
    2 weeks ago i had a new radiator fitted,my blowers worked fine, last night my heater stopped blowing hot air when it was idling and only tepid air when travelling.I tried letting it overheat with the cap off to remove any air. this worked for about 30 mins then it went back to the problem again.If i rev the engine it warms up then goes cold when i stop revving.What the hell is going on ??
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Sounds like thermostat fail to me - ie jacked open.
    Grimsby uk
    Is there a way by feeling the pipes to pinpoint the problem ?
    Feb 2012
    Dover
    Take your thermostat off and stick it in a pan of boiling water to see if it opens or shuts.
    Will let you know if the thermostat is faulty.
    Grimsby uk
    ok thanx
    Dec 2011
    Seaham
    Does the temperature gauge come up to its normal position within 4-6 miles and stay at that temperature?
    Jun 2011
    Herts
    let the car idle and as soon as the needle moves feel the 2 big pipes that go to the stat and if both are warming at the same rate the stat is royally ragged and locked leaving loop open.
    Grimsby uk
    Yes the gauge comes up as normal and stays there. I've noticed tonight that all of my pipes are very hot except for the left hand one coming from the matrix which is considerably cooler than the right hand one. Hope this helps.
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    Sounds like a blocked matrix to me. Had this problem on my corsa. Got I changed and worked a treat. You could also flush the system out or take the matrix out and flush that. Its a messy job though
    Dec 2011
    Seaham
    Could just be an airlock? Or I hate to say, if the water pump is starting to fail? Try back flushing the matrix first.
  1. Heater blows hot only
    By laingyc in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2011, 10:57
  2. Heater only blows cold
    By Harry Hammer in forum Vectra C / Signum Troubleshooting
    Last Post: 21st March 2011, 20:55
  3. Heater only blows hot
    By GoldenWonder in forum Bodywork & Interior
    Last Post: 17th March 2011, 12:59
  4. Heater blows hot & cold
    By manimal in forum Bodywork & Interior
    Last Post: 22nd November 2010, 23:45
  5. Heater only blows cold
    By b-e-r-t in forum Electrical & ICE (including SatNav)
    Last Post: 15th April 2008, 13:30
