Thread: Anti roll bushes size?
    Jan 2012
    Cornwall
    Default Anti roll bushes size?
    Hi could anyone tell me how to find out what size anti roll bushes I've got, without having to take them off the car. I understand there are 25mm and 24mm sizes.
    I will be replacing both front and rear sets of bushes and the engine code is z18xe.
    Any help would be appreciated
    Thanks, Martin.
    Regular Member nick-v2.2's Avatar
    Nottingham
    get a caliper gauge on the bar as close as possible to the bush.
    Worked to find out my own. only two sizes 24.2 and 25.2
    You may also be able to read part number on the bush.
    If it begins 24 its the 24.2 if it starts 91 its the 25.2
    HtH
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    I might be wrong but i'm lead to believe that, if the bush itself has 2 nobbles on it it's 25mm but if not it's 24mm. Might be wrong though. I just measured mine using an adjustable spanner, clamping it up around the anti roll bar then reading the measurement
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Just get the part number off the old ones (it's embossed on the sides of them) and punch it into Google or your search engine of choice, alternatively post it up here and someone will tell you
    Jan 2012
    Cornwall
    Thanks for the advice, I'm changing my drop links and front and rear bushes at the weekend so hopefully that crunching sound will disappear
    Regular Member portreathbeach's Avatar
    Jan 2012
    Cornwall
    I just put a vernier on the front ARB and it read 25.5 and the rear rear 17.75.
    Does that mean I need the 25.2mm ARB bush for the front and the 17mm for the rear?
    I can't see any part numbers or markings on them and I don't really want to order a few different sizes and have left over ones.
    Full Member spennny's Avatar
    Blantyre
    Rears are all one size are they not ?
    Jan 2012
    Cornwall
    That's about what I got when I measured mine, I fitted the 25mm and 17mm and they went on fine, if you can't see the part numbers try a light and mirror but as you know access is a bit awkward.
    Blantyre
    Is your crunching gone as I have this on my RHS , I think it could be strut bearings though ?
    Jan 2012
    Cornwall
    Yes the crunching is gone, it looked like it was the right drop link but I changed the bushes anyway.
  1. Anti-Roll Bar Bushes
    By Monkgti in forum Suspension, Wheels & Brakes
    Last Post: 2nd February 2013, 20:56
  2. Anti roll bar bushes
    By Mark-R in forum Handling & Braking
    Last Post: 27th April 2012, 14:13
  3. Anti roll bar bushes
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2011, 22:06
  4. Anti roll bar bushes
    By wilson002 in forum Suspension, Wheels & Brakes
    Last Post: 2nd May 2008, 21:43
  5. Anti roll bar bushes FOC
    By LAV6Y in forum Parts for sale
    Last Post: 4th April 2008, 20:25
