Thread: Engine cut out and poor running, Z22SE
    Leeds
    Default Engine cut out and poor running, Z22SE
    My 2.2 sri 03 plate has started running poorly on and off recently and yesterday cut out for no reason and took ages to fire up again.
    When i got home from work i plugged in my code reader and 2 codes came up:
    P0171 - System to lean bank 1
    P0340 - Camshaft possition sensor A circuit bank 1 or single sensor
    Not really sure what these mean or what i need to do to fix the problem? ive reset the codes and the car is running ok so far. A few weeks back i had the coil pack replaced as they thought it was that which was making the car run bad but apparently not!
    Any help would be gratly appreciated as i dont want to take the car on a motorway if theres a chance it could cut out again.
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Rushy is the man ge will be somewhere about
    Leeds
    Spanner light came back on today, about to go scan for codes again!
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    " P0340 - Camshaft possition sensor A circuit bank 1 or single sensor"
    Quote Originally Posted by MikeS
    only camshaft sensor fault on z22se is fake
    p0340
    it means coil pack is fudged or lack of compression as the ecu uses the coil pack for timing
    Quote from the 2.2 forum.
    Vehicle : SRi
    Mileage : 137000
    Another member had the same P0340 code, he replaced the coil pack and nothing, then replaced the plugs and it sorted it mate.
    This guy is god when it comes to the Z22SE
    Quote Originally Posted by benny
    these engines dont have a cam shaft sensor fitted ..unless its a 2.2yh ......i would say either number 1 spark plug has had its day ..or you have damaged the wiring loom that goes to the dis pack ..or the dis pack is faulty ... ....try swapping a spark plug over ...or trying the plug on the dis pack for being loose ....hope this helps
    Leeds
    Thanks for the responce,
    Same 2 codes came back up today.
    As ive already had a new coil pack ill try out some new plugs but im sure they said they replaced them at the same time (probably with some cheap rubbish)
    Whats the best make of plugs to get?
    Vehicle : SRi
    Mileage : 137000
    For the Z22SE the best ones are actually the factory ones.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Has the chain slipped or streched? Was the chain noisey on cold start?
    lincolnshire
    as above , surely the poor starting points to something other than spark issue ?? i hope it is plugs of course
    Leeds
    Not getting any chain noise that i can hear to be honest but then ive not really been listening for it! ill check in the morning.
    Is it a short type of ratttle or will the rattle be there till the engine warms up? or will it be obvious when i start her up?
    On the plus side no spanner light or bad running today!
  1. Vectra Z18XER Poor Running
    By mxspyder in forum Engine & Drivetrain
    Last Post: 12th March 2012, 11:13
  2. cold start smoke and poor running engine
    By Tredici in forum Engine & Drivetrain
    Last Post: 16th January 2012, 08:40
  3. Poor starting and slight misfire on z22se
    By Nato in forum Engine & Drivetrain
    Last Post: 5th June 2010, 23:55
  4. car wont start and poor running help pls
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 3rd January 2010, 21:16
  5. 1.8 Poor running - Help!!
    By abbeytec in forum Vectra C / Signum Car Chat
    Last Post: 18th September 2008, 19:29
z22se wants to cut out
p0171 z22se
vectra c z22se cutting out
vauxhall insignia fault code p0171 and chain slack
