Thread: Possible temp gauge issue??
    Regular Member mcpitman's Avatar
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    Default Possible temp gauge issue??
    Evening,
    Had the thermostat changed on my 1.9 cdti 120 today, due to it showing no temp on the dash, then rising to about 75 when in traffic and then dropping again. (Classic thermostat issues)
    Economy has dropped, but the heaters have always got warm.+
    However, even with the brand new thermostat is working fine, the temp gauge still isn't playing ball, and won't show temperatures.
    I did have the dash replaced last year after it went pop, maybe I should pop it back to the dealers and see what happens there.
    Any thoughts?
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    What year is the car?
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    Quote Originally Posted by mattv6diesel View Post
    Knew I forgot summat... 2004
    When plugged into garage diagnostics it comes up with "pod fault".
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    You need to use the data lists with a diagnostic tester if the insrument data says it should be showing 80oC but the guage hasn't moved you know the facia had a fault.
    Asked the year cause the newer radios ( cd30, cdc40 ) you can push radio on push settings for 15 secs till a beep sounds then push BC and it scrolls through menus one has speed and temp so u can see exactly what the engine is doing
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    Thanks for the above....
    Sadly I have a club spec, which doesn't have the OBC. I do however have a cd30 radio/cd.
    I need the car for work tomorrow, so the mechanic is picking it up again on Saturday. I will get hom to take some live data through the diagnostic then.
    Does this sound more like a dash issue to you? It appears to beheading that way to me?
    On a side note will the engine overfuel at all due to the temp gauge not working? Or could it be the cold weather that has decreased the fuel economy recently?
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    Well it's sorted now, battery off and back on and the temp gauge started working again. As always if anything breaks...at all... ever.... switch it off and back on again.
    Oh yeah and on reinputting the radio code noticed I have a cdr2005... not a cd 30.
    morecambe
    33 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Yep u will have as your car is 2004 it's half canbus only full canbus cars have cd30
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    What is the difference between half canbus and full canbus, apart from the steering wheel buttons? What do you get with full that you don't with half?
  1. temp gauge ?
    By hippo in forum The 'Off Topic' room
    Last Post: 6th February 2012, 18:33
  2. temp gauge issue on 1.9 cdti
    By robk6112 in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2009, 14:54
  3. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  4. temp gauge
    By ryanhamil in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2009, 21:35
  5. Temp. Gauge
    By cdtisri in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2007, 10:42
vectra c 1.9 cdti temp gauge not working
56 vectra t3mp gauge not working
vectra c cdti temperature gauge not working
temp gauge isnt working vectra c cdti
https:www.vectra-c.comforumshowthread.php156039-Possible-temp-gauge-issue
temp gauge not working in vectra c facelift
vectra cdti temp gauge not working
vauxhall zafira temperature gauge not moving
vectra c temperature gauge not rising
vectra c thermostat derby
