Thread: Code readers
    May 2011
    Stockport
    Default Code readers
    Hi all. Relatively new to the Veccy C, and my 54 plate 2.0DTi has started showing the spanner in the display when I start it. It goes of after 20-30 seconds though.
    So I was wondering what the best (read CHEAPEST) way is to get the codes. Needless to say I am not a fan of the Stealerships. I only want to lift codes, not start changing anything.
    I assume there is no Paperclip test like on my old veccy, I have already searched for that. Are the readers on ebay ok? they seem to go from £20 for USB wotsits up to £50 for all in one's.
    >boggle<
    Rick
    Regular Member kevinmc's Avatar
    Jan 2012
    Ireland
    2.0 DTI glow plugs, providing it doesn't come on when engine is warm m8.
    May 2011
    Stockport
    I was thinking that, as it sometimes struggles a bit. (My first Diesel O.o )
    thanks
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    A local garage will be able to read codes for about £30
    Search for pedal trick give that ago first as you might be able to get codes for free
    Jan 2010
    Trim : 1.9 cdti
    Engine : 150 Z19DTH
    Year : 08
    As said, glow plugs need changing. Could be one or two that have gone but better to change the whole four for peace of mind. Easy to change and will only require 10mm deep socket and some wd40. NGK part number Y-523J, stock number 3703.
    P.S. pedal trick does not work on 2.0DTi.
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Yeah I thought it might not work as doesn't work on 1.9 either but thought was worth a try
  1. Error code reading and code readers
    By Ben50n in forum Engine & Drivetrain
    Last Post: 27th August 2012, 16:43
  2. code readers
    By J P S in forum Vectra C / Signum Troubleshooting
    Last Post: 29th May 2012, 19:13
  3. Code readers
    By s2yob in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2011, 15:13
  4. Code readers
    By barney490 in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2010, 20:09
