Thread: Front Anti roll bar bracket question?
    Regular Member MURDO's Avatar
    Co.Clare, Ireland
    Vehicle : Opel Vectra GTS Sport Z18XE
    Trim : Matt Sivler
    Engine : Z18XE
    Mileage : 170,000
    Default Front Anti roll bar bracket question?
    Afternoon all,
    [IMG][/IMG]
    Not sure if you can see from the picture, but the bracket holding the ARB bush in place has loosened slightly. I had to tighten it back down there around Sept 2011, and again there today.
    Just wonder if there could be an underlying problem i haven't thought of here.
    Perhaps do i need to change the bushes out??
    Any advice would be great.
    Thanks in advance.
    Ade
    wirral
    33 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Are the threads on the bolt ok?
    They shouldn't be coming un done but at same time I think their only tightend to around 10nm
    Might be an idea to change the bushes since their only a couple of quid each and then put a small dab of thread lock on
    Regular Member Cyruskint's Avatar
    Jun 2009
    Dorset
    Quote Originally Posted by Critch View Post
    Sound advice there - most bolts come with some form of threadlock from the factory, so on low torque fixtures like that (subject to oodles of vibration) I would imagine they could work loose. I have ordered some new bushes (Thought I'd try privet for a change ) so will have to see if my bolts are loose.
    South east
    Given the s*****y access you have to the bolts though, if you threadlock them they'll be near impossible to remove next time.
    wirral
    33 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Small dab shouldn't make that much of a difference.
    And should get the out easy enough with 10mm ratchet spanner
    Jun 2009
    Dorset
    Very true - if you see how much is used from factory, the little dob you need is nothing (but should stop you unwinding like you've overdosed on your evening Ovaltine
    Co.Clare, Ireland
    Trim : Matt Sivler
    Engine : Z18XE
    Mileage : 170,000
    Quote Originally Posted by Cyruskint View Post
    thanks for this lads. Picked some thread lock up from work and have the bushes also.
    All i need now the weather.
  1. Front Anti-Roll Bar New 25.2mm
    By paulhb in forum Parts for sale
    Last Post: 7th March 2010, 14:14
  2. TIS Help? Front Anti-Roll Bar Replacement
    By paulhb in forum Suspension, Wheels & Brakes
    Last Post: 2nd March 2010, 22:56
  3. *New* front anti roll bar 25.2mm
    By danBoy in forum Parts for sale
    Last Post: 10th February 2010, 22:44
  4. Front anti roll bar
    By Tom Tom in forum Suspension, Wheels & Brakes
    Last Post: 30th July 2009, 18:38
  5. Anti roll bar bushes-quick question
    By LAV6Y in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2008, 15:55
