Results 1 to 10 of 11
Thread: Washer Jet Adjustment on 1.9CDTi
    northampton
    Default Washer Jet Adjustment on 1.9CDTi
    Can someone tell me or post me a "How To" on adjusting the front washer jets on my Veccy. The passenger one is fine but the drivers one fire water too low on the screen?
    Feb 2011
    Selby
    The washer jets on a Vectra (as with most cars) are a metal ball with a hole through the middle, held in a plastic unit.
    Get a pin. Stick it in the hole. Move the pin to swivel the ball in the housing. Remove pin. Try washers. Repeat until they're squirting in the place you want them to. You don't need to move them much generally.
    Jul 2011
    UK
    Year : 06
    Buy insignia washers much better
    Regular Member farley2708's Avatar
    antrim n.ireland
    £5-£6 either in dealers or on ebay................far better job
    Regular Member Barlow's Avatar
    Jan 2012
    Chester
    Vehicle : Nissan 350Z GT
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Curious. What do Insignia ones do that Vectra ones don't
    May 2011
    bispham, blackpool
    they spray a mist so the whole screen gets wet much better
    but i dont know how to adjust the insignia ones so half of it goes over the roof on mine
    Engine : 1.9 CDTi
    Quote Originally Posted by 6009tristanb View Post
    Make or buy on of these (I have one at work): http://www.ebay.co.uk/itm/INSIGNIA-A...item3a6fe74519
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    make the tool out of a biro for free !
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    I tried making one out of a biro but wouldnt move them and the plastic just cracked.
    Sent from my iPhone using Tapatalk
    Feb 2011
    Selby
    Indeed - the Insignia fan shaped spray ones are just the same idea (a metal ball), but the hole is a different shape. So you can't lever it about using the hole, you have to press on specially designed parts of the ball with a tool to move it.
    Straight swap anyway if you fancy them. I'd settle for mine not freezing (have got 50/50 diluted screenwash in at the moment, and it was -8 this morning). So I might go for the heated Vectra ones
  1. hatch adjustment
    By jamiedvvt in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2012, 14:52
  2. MPG adjustment on Op.com
    By mally in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2011, 12:40
  3. lights adjustment
    Last Post: 30th December 2010, 20:43
  4. Quick question - Rear Washer Jet Adjustment (08 Plate Hatch)
    By king_chris in forum Vectra C / Signum Troubleshooting
    Last Post: 8th March 2010, 02:02
  5. Pics Adjustment
    By MRLUBBERLUBBER in forum Quick Photo Album
    Last Post: 17th December 2006, 23:27
