Results 1 to 10 of 22
Thread: water levels low
    May 2011
    sunderland
    Smile water levels low
    Hi guys,ive gotta vectra cdti 1.9 recently it has been loosing water no leaks i can see then the warning light comes on stating low coolant but when i loosen the expansion cap off then the water levels rise in the tank any ideas guys???
    wirral
    33 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    What level is it before starting engine? Do you have to actually top it up?
    May 2011
    sunderland
    Sorry for the delay in replying its just below the cold water level but when i take off the cap it fills back up also the temp gauge rarely moves thanks in advance
    wirral
    33 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Shouldn't move first think in morning before starting.
    Could be an air lock in the system somewhere.
    If you top it up to just above the cold marker take it for a drive, get it up to temp and then see if the level drops.
    As could be head gasket on way
    May 2011
    sunderland
    Angry
    I filled it about an inch above the cold water line ran it till the engine got warm then the level dropped to about the cold line but when i take the expansion cap off it goes back to above the level ?????
    wirral
    33 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Is that you driving around? Or just leaving it idle?
    Glasgow
    First of all dont take the cap of when the engines hot there is a risk you ended up scalded by steam or boiling coolant.
    If the coolant level always returns to the same level when the engine is cold then i suggest the sensor for the coolant level needs replaced.
    May 2011
    sunderland
    It does it both when the car is idling the level drops,turn the car off the level rises
    May 2011
    sunderland
    Sorry forgot to say only rises when the cap is taken off
    Dec 2011
    Seaham
    The water level will rise when you take the cap off as you are releasing the pressure in the system.
  1. Dipstick oil levels?
    By PeterVV in forum Engine & Drivetrain
    Last Post: 23rd April 2011, 01:01
  2. Oil levels.
    Last Post: 29th August 2010, 14:42
  3. User levels...
    By Penfold101 in forum The 'Off Topic' room
    Last Post: 20th February 2009, 19:29
  4. vectra-c.com levels
    By aaruck in forum The 'Off Topic' room
    Last Post: 20th June 2008, 01:56
  5. How many O levels to be a builder!
    By MLC in forum General Chat
    Last Post: 30th June 2007, 00:16
