Results 1 to 10 of 14
Thread: "How To" on fitting Oil Sump??
    Feb 2012
    Wolverhampton
    Default "How To" on fitting Oil Sump??
    Apologies if in wrong section
    After a little incident I had the weekend, I need to replace my Sump....
    Is there guide on how to do this for a 120 1.9 Cdti??
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Don't think theirs a guide. But I think you may have to drop sub frame to give clearance to remove it.
    Not always the best way about going about a job but getting a Haynes manual might be worth it.
    Or even just go stand in Halfords read the page a few times and go home
    Feb 2012
    Wolverhampton
    Quote Originally Posted by Critch View Post
    thanks for the reply..... Was thinking of a Haynes manual
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Sorry couldn't be of more help.
    But apart from clearance to remove the sump. Their usually fairly straight forward to take off.
    just make sure get a new gasket aswel
    Feb 2012
    Wolverhampton
    No worries.... I found this on a previous thread.... Seems a lot to remove tbh
    Quote Originally Posted by plasma View Post
    Not a nice job, Involves removing one of the driveshafts, dropping the gearbox fluid, removing the front end exhaust system and some other bits... Gave mine to someone to do lol
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Sounds like a fairly involved job. Thinking about it yeah intermediate shaft might be in the way.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    cant seem to get pictures atm but this is what if got from tis might be some help
    Remove and install oil pan
    J456500
    Remove
    1. Open bonnet
    2. Disconnect battery.
    3. Release oil dipstick guide tube at the top
    • Remove bolt
    4. Release front wheel
    • Release 5x bolt
    5. Raise vehicle
    6. Detach front wheel
    • Unscrew 5x bolt
    7. Remove swing arm (2)
    • Unscrew nut
    – Counterhold at flat with open-ended wrench
    8. Detach tie rod ball joint
    • Unscrew nut
    • Push down off steering knuckle with KM-161-B (1) and KM-161-2
    9. Detach guide joint (3)
    • Remove screwed connection (4)
    10. Press out axle shaft
    • From intermediate shaft
    11. Raise vehicle
    12. Detach lower engine compartment cover and right-hand engine splash protection if necessary
    13. Remove intermediate shaft
    • Detach intermediate shaft bearing support (1)
    – Unscrew 3x bolt (2)
    • Remove intermediate shaft with support
    14. Seal off transmission aperture
    15. Remove front exhaust pipe
    Important: When removing the central silencer, a catalytic converter, an exhaust manifold or an exhaust manifold with catalytic converter, the part of the exhaust system remaining in the vehicle must be secured to prevent it sagging. To do this, the section of the exhaust system with the flex pipe contained in it can be fastened to the substructure of the vehicle with suitable means such as e.g. wire or the transportation fittings for a new flex pipe. Bends of as little as 5 - 10 degrees in the flex pipe can lead to damage resulting in total failure of the flex pipe.
    • Unscrew 6x nut
    • Release exhaust pipe bracket
    – Unscrew 2x bolt
    16. Detach catalytic converter bracket (2)
    • Unscrew 3x bolt (1)
    17. Detach torsional vibration damper
    • Release 4x bolts
    18. Remove ribbed V-belt
    • Mark direction of movement of ribbed V-belt
    • Tension the ribbed V-belt tension roller at bolt (1) in a clockwise direction (direction of arrow)
    • Insert KM-6349 (2)
    19. Remove torsional vibration damper
    • Unscrew 4x bolt
    20. Disconnect compressor wiring harness plug
    • Release wiring harness plug
    21. Remove compressor
    • Unscrew 3x bolt
    22. Remove compressor bracket (3)
    • Unscrew 4x bolt (2)
    • Unclip wiring harness bracket (1)
    • Remove bracket with guide roller (4)
    23. Open oil drain bolt
    • Place collecting basin underneath.
    • Unscrew oil drain bolt
    24. Release oil dipstick guide tube at the bottom
    • Remove bolt
    • Remove bracket for wiring harness plug
    25. Detach wiring harness plug of dynamic oil level check sensor (1)
    26. Detach oil return hose (2)
    • Release clamp
    27. Screw in oil drain bolt
    • Replace seal ring
    • Banjo bolt 20 Nm
    28. Position flywheel
    • Turn engine in direction of rotation
    – At crankshaft bolt
    – Until flywheel recess releases the bolt (arrow)
    29. Release oil pan on transmission side
    • Unscrew 2x bolt
    – On transmission
    • Unscrew 2x bolt
    • Use EN-46794
    Note: The flywheel must be turned again so that the second bolt is released.
    30. Release oil pan on the engine timing side
    • Unscrew 2x bolt
    • Use EN-47631
    31. Remove oil pan
    • Unscrew 10x bolt
    • Use EN-46796
    • Release oil pan with KM-J-37228
    32. Detach oil intake pipe
    • Unscrew 2x bolt (arrows)
    33. Remove oil pan
    Note: Remove oil pan with oil intake pipe
    Install
    34. Cleaning work
    35. Position oil intake pipe
    • Replace seal ring
    • Screw in bolt
    – In crankshaft bearing cap
    Note: Only screw bolt in to the point where the oil intake pipe can still be swivelled.
    36. Apply sealant
    Important: Complete assembly operations within 10 minutes.
    • Apply sealant to sealing surface of oil pan
    37. Position oil pan
    Note: Position oil intake pipe in oil pan, to do this swivel oil intake pipe backwards (connection to oil pump)
    38. Attach oil intake pipe
    • 2x bolts 9 Nm
    39. Attach pan
    • Position oil dipstick guide tube
    Note: Ensure that the sealing bead is undamaged.
    • Position 10x bolt
    40. Fasten oil pan on engine timing side
    • Position 2x bolt
    41. Position flywheel
    42. Fasten oil pan on transmission side
    • Position 2x bolt
    • Use EN-46794
    Note: The flywheel must be turned/positioned again so that the second bolt is released.
    43. Fasten oil pan
    • 10x bolts (M8) 25 Nm
    • 4x bolts (M6) 9 Nm
    • 2x bolt (transmission, M10) 40 Nm
    44. Attach oil return line
    • Fasten clamp
    45. Connect dynamic oil level check sensor wiring harness plug
    46. Attach compressor bracket
    • 4x bolts 50 Nm
    • Clip in wiring harness bracket
    47. Attach compressor
    • 3x bolts 22 Nm
    48. Connect compressor wiring harness plug
    • Lock wiring harness plug
    49. Fasten oil dipstick guide tube at the bottom
    • Bolt 9 Nm
    • Attach wiring harness plug bracket
    50. Place torsional vibration damper in position
    • Screw in 4x bolt
    Note: Ensure correct installation position.
    51. Install ribbed V-belt
    Note: Pay attention to direction of travel
    • Install ribbed V-belt.
    Ribbed V-belt routing with air conditioning system
    Ribbed V-belt routing without air conditioning system
    • Remove KM-6349
    52. Fasten torsional vibration damper
    • 4x bolts 360 Nm
    53. Install intermediate shaft
    • Attach intermediate shaft bearing support
    – 3x bolts 55 Nm
    54. Attach catalytic converter bracket
    • 3x bolts 25 Nm
    55. Attach front exhaust pipe
    • Replace 6x nut, 2x gasket
    • 6x nuts 20 Nm
    • Fasten exhaust pipe bracket
    – Tighten 2x bolt
    56. Lower vehicle
    57. Replace retaining ring
    • From axle shaft
    58. Install axle shaft
    • In intermediate shaft
    59. Attach guide joint
    Note: Replace nut and bolt.
    • Nut 60 Nm
    60. Attach swing arm
    Note: Replace nut
    • Nut 65 Nm
    Note: Counterhold with open-ended wrench.
    61. Attach tie rod ball joint
    Note: Replace nut.
    • Nut 35 Nm
    62. Raise vehicle
    63. Attach lower engine compartment cover and right-hand engine splash protection if removed
    64. Lower vehicle
    65. Attach front wheel
    • Screw in 5x bolt
    66. Lower vehicle
    67. Secure front wheel
    • 5x bolts 110 Nm
    68. Attach oil dipstick guide tube at the top
    • Bolt 9 Nm
    69. Connect battery.
    70. Program volatile memories
    71. Top up engine oil.
    • Observe specified engine oil quantity
    • Start engine and allow to run until oil pressure telltale extinguishes.
    • Check engine oil level, if necessary correct.
    72. Close bonnet
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    J456500
    Remove
    1. Open bonnet
    • Remove bolt
    • Release 5x bolt
    5. Raise vehicle
    • Unscrew 5x bolt
    • Unscrew nut
    • Unscrew nut
    11. Raise vehicle
    • Unscrew 6x nut
    – Unscrew 2x bolt
    • Release 4x bolts
    • Unscrew 4x bolt
    • Unscrew 3x bolt
    • Remove bolt
    • Release clamp
    • Replace seal ring
    • Banjo bolt 20 Nm
    • Unscrew 2x bolt
    – On transmission
    • Unscrew 2x bolt
    • Use EN-46794
    • Unscrew 2x bolt
    • Use EN-47631
    31. Remove oil pan
    • Unscrew 10x bolt
    • Use EN-46796
    33. Remove oil pan
    Install
    34. Cleaning work
    • Replace seal ring
    • Screw in bolt
    36. Apply sealant
    • 2x bolts 9 Nm
    39. Attach pan
    • Position 10x bolt
    • Position 2x bolt
    • Position 2x bolt
    • Use EN-46794
    43. Fasten oil pan
    • Fasten clamp
    • 4x bolts 50 Nm
    • 3x bolts 22 Nm
    • Bolt 9 Nm
    • Screw in 4x bolt
    • Remove KM-6349
    • 4x bolts 360 Nm
    – 3x bolts 55 Nm
    • 3x bolts 25 Nm
    • 6x nuts 20 Nm
    – Tighten 2x bolt
    56. Lower vehicle
    • From axle shaft
    • Nut 60 Nm
    Note: Replace nut
    • Nut 65 Nm
    Note: Replace nut.
    • Nut 35 Nm
    62. Raise vehicle
    64. Lower vehicle
    • Screw in 5x bolt
    66. Lower vehicle
    • 5x bolts 110 Nm
    • Bolt 9 Nm
    72. Close bonnet
    Feb 2012
    Wolverhampton
    Thanks alot!!!! A great help!
    Just had a quote of £600 from garage to do the job
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    That's the worst double post ever!
  1. Fitting a "Working" DVBT Television for mobile use. Decent Systems - A Vx Head Unit
    By Woody in forum Electrical & ICE (including SatNav)
    Last Post: 9th February 2013, 02:37
  2. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  3. Fitting "Standard" Radio/CD to Vectra
    By dc6839 in forum Electrical & ICE (including SatNav)
    Last Post: 17th July 2011, 19:15
  4. Anybody changed a sump on "06" petrol vectra
    By scott_vectra in forum Engine & Drivetrain
    Last Post: 20th September 2009, 14:56
  5. Halfrauds Free Fitting "bodge" And Pass The Buck
    By shan in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2007, 23:10
vectra c oil sump replacement
vectra c sump replacement
