Results 1 to 10 of 22
Thread: number plate light screws wanted
    wales
    Default number plate light screws wanted
    hi i want to put a new bulb in my number plate light but the screws look as if they will self - destruct if they see a screw driver....so wher can i get these from..?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Number plate bulb holder should just pop out and then twist and pull the bulb holder
    Not on the facelift cars it wont. As said by o.p. two screws holding each lens and they are usually rotten when you need to remove them if they have not been touched for years.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Aaahh learn something new everyday.
    I assumed they would have kept them same. As my 2007 Astra had same bulb holder as my 04 vec
    take it they will be just some self tapping screws then. So Halfords or any motor factors should have various screws in.
    wales
    Critch they are like Repala said and they have never been touched
    Regular Member Keif's Avatar
    In the Garage
    Mine did self destruct when touched, you wont get them out with out damaging the light unit. I tried drilling them out, but ended up having to break the lens from under the screw head and use mole grips to undo them. The lens is plastic and very brittle so not that bad to sort.
    The screws are 4mm diameter and about 10mm long (they go into a large gap, so longer will be fine). I've added a washer in my new number plate lights, just to give me a fighting chance when i need to change a bulb.
    Also, it's easier to take the inner trim off the tailgate and undo the 7 nuts holding the strip with the lights in on a Signum. You can sort in on a bench then.
    Part Number for Signum Number plate light is 90213642.
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    i have an estate, are the lights screwed in on there, i have bought a reversing camera to replace one light and it looks like its designed to clip in
    In the Garage
    All Vectra Numberplate lights clip in, Signum ones screw in.
    wales
    cheers guys..
    J P S that sounds nice any pics..
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    I had to do that on my old signum but i managed to get the old screws out. When i replaced the screws i coated them in copper grease
  1. Number plate light
    By ronaldodg9 in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2012, 05:18
  2. Number plate light module
    By blue estate in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2012, 00:46
  3. Tail light/number plate light wiring...
    By kyuudousha in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 12:34
  4. Number Plate Light
    By kiwigolfer in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2009, 23:10
  5. Quick question: Number plate screws: Metal or Plastic???
    By RSV_Ecosse in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2008, 00:09
