Thread: reading injector values opcom
    Jul 2011
    retford
    Default reading injector values
    guys, i think i have a injector problem on my cdti 150 can some one interpret these values for me please
    cylinder 1 -4.67
    cylinder 2 2.70
    cylinder 3 5.06
    cylinder 4 -3.23
    all read on idle.....
    very new to veccy diagnostics so im not sure what the values should be, or where the issue is.....
    thanks in advance
    Jul 2011
    retford
    oh dear..... genuine version guys. cmon helpful posts please
    Jul 2011
    retford
    edited to reduce unwanted flaming
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    why do you think you have a injector problem fella?
    also cylinder 2 looks a little low but cylinder 4 is that a minus-3.23
    Jul 2011
    retford
    hesitation and really rough start..chugging.
    egr is fine, boost pipes are fine, swirl bar is fine.
    ive run injector cleaner through it, no avail....
    quite a loud ticking all the time, run some tappet cleaner through, no results.
    on idle revs theres smoke albeit a small amount coming from injector 1.
    ive done 3rd injector mod.
    so i decided to read the values
    yes cylinder 4 is -3.23
    cheers
    Jul 2011
    retford
    also these readings are from properly cold start... no revving or anything.
    Jul 2011
    retford
    can anyone elaborate on these readings?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Quote Originally Posted by james walker View Post
    No isnt legal, as it then would have been vauxcom, as you are a UK resident.
    thread closed.
  1. Vectra c 1.9 8v Opcom Injector values
    By zippygsi in forum Engine & Drivetrain
    Last Post: 25th November 2011, 20:26
  2. Injector Wiring Loom (common fault on 3rd injector)
    Last Post: 8th October 2010, 12:18
  3. emissions values for 2.2 Direct
    By DaveG in forum Engine & Drivetrain
    Last Post: 3rd April 2010, 15:07
  4. Used Car Values - Good News!!
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2009, 17:19
opcom injector readings
vauxhall vectra cdti injector opcom readings
https:www.vectra-c.comforumshowthread.php155995-reading-injector-values-opcom
opcom how to read injectors
opcom injector
opcom corsa c injector test
