Results 1 to 2 of 2
Thread: Transmission Fault code P0785 Shift Timing Solinoid Valve open or low input.
    Hamilton, New Zealand
    Default Transmission Fault code P0785 Shift Timing Solinoid Valve open or low input.
    Hi
    Our 2002 Vectra C (engine Z22SE) had developed this fault with the transmission. The Fault that GM Holden have advised the problem is from code P0785 Shift Timing Solinoid Valve open or low input.
    They took a sample of the trans oil and reported that it is very black indicating an internal fault.
    The car goes into emergancy management mode, and i do notice that it appears to "Grab" while putting the car into reverse.
    GM advice is to remove and rebuild the transmission or replace with a 2nd hand transmission. Both these costs are quite expensive from $4000.00 to $6500.00.
    Could there be something more simpler that could be generating this fault? or is what they have advised is this correct?
    Default Help please - Fault P0785 - Car Spanner symbol
    I have had the same with the car spanner symbol and with the car going into limp mode etc
    The error code was P0785 Shift Timing Solinoid valve.
    The oil in the transmission is black indicating an internal fault.
    Two options have been given to me by an Auto transmission mechanic
    one to replace the Solinoid and new oil and see if that fixes the problem.
    Or expensive option to rebuild the transmission.
    If the solinoid is at fault would this cause the oil to go black? or should i be looking at the transmission rebuild?
    Any idea help would be great.
  1. Fault code po403 exhaust gas recirculation valve.faulty.
    By Dobs in forum Engine & Drivetrain
    Last Post: 8th September 2012, 13:37
  2. Replies: 11
    Last Post: 26th June 2011, 19:29
  3. Replies: 9
    Last Post: 15th October 2010, 17:57
  4. cdr2005 code input
    By ensign2006 in forum Electrical & ICE (including SatNav)
    Last Post: 15th July 2009, 15:34
  5. Automatic Transmission down shift problem
    By miled0898 in forum Engine & Drivetrain
    Last Post: 12th August 2008, 08:02
0pel vectra fault code P0785
opel vectra c fault code P0785 shift timing solenoid
p0785 opel vectra c 2 2
opel vectra c shift solenoid high input P0785
po785 holden
