Results 1 to 10 of 19
Thread: Erm... Help!
    Regular Member lew1984's Avatar
    Jul 2011
    Cheshire
    Default Erm... Help!
    Hey guys,
    Well tonight when I was driving home, I discovered on the off chance that there is a strange sound coming from my engine.
    Now the best way I can describe it, is that it sounds like a bit of plastic running against the spokes of a bike wheel (you know what you use to do when you was a kid) I'm not saying something is stuck running against something... its the sound it makes thats the closest thing to describe it!
    Now the engine runs fine, no loss of power. I've checked the oil, that also is fine... just slightly over the max line but other than that... I cannot hear anything see anything that seems out of place.
    When the engine is idling, it sounds normal.... it's only when I set off it starts to make that noise!
    I don't know if this matters but there's a K&N air filter on the car so it makes it sound a lil more gruntier if you get what I mean... i'm not getting this effect as much now, only if I rev it when car is idle.
    So what do you all think?
    Lew
    Regular Member mattv6diesel's Avatar
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Year : 2008
    Well if its moving it would be wheels some thing. Mud flaps touching a wheel?
    Jul 2011
    Cheshire
    Quote Originally Posted by mattv6diesel View Post
    Yea I checked that but they're fine... its definitely coming from the engine bay... im sure of it! :-S
    Jul 2011
    UK
    Year : 06
    Gearbox bearings had this on 206 took ages to find what was wrong
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Year : 2008
    Hard to know with out seeing. Can someone drive whilst you look? If its pulling away would gess transmision or drive shafts area. Does it doing just reving the engine?
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Year : 2008
    What engine & gear box
    Jul 2011
    Cheshire
    Its a 2.2 SRI 2003 (Non-direct) not sure about gearbox tbh
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Does it do it when revving in neutral?
    Is is still there when driving and dipping the clutch?
    And when putting in neutral whilst still travelling?
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Year : 2008
    Quote Originally Posted by lew1984 View Post
    Just ment auto or man
    Jul 2011
    Cheshire
    Its happens when i put my foot down but if at a steady constant speed then its fine.
    If i change or drop a gear and put foot down again its more noticeable.
    When its idol/neutral then it sounds fine. If its idol and rav the engine... again the usual noise ud get from the air-filter is what I hear.
    Its very strange
