Results 1 to 10 of 15
Thread: Spark plug replacement 2.2.direct (z22yh) advice.
    Jun 2009
    Middlesex
    Default Spark plug replacement 2.2.direct (z22yh) advice.
    I need to replace the spark plugs on my 2.2.Direct (o4 reg) z22yh.
    I have never replaced these before on this vehicle.Can anyone advice as to the procedure and any tips i would find helpful.
    Many Thanks Dobs.
    ijk571
    Guest
    Don't use a screwdriver to lever off the coil pack!! . Mine was very stiff to remove so I used one to help it off and broke off at little bit of the plastic casing.
    Sent from my GT-I5800 using Tapatalk
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Don't over tighten them, just give them a good nip up.
    11 Post(s)
    I imagine it'll be the same or very similar as the how2 for changing the plugs in the 2.0.
    Jun 2009
    Middlesex
    Is there better to remove the plugs while the engine is still warm.How is the coil pack held down.Is it attached with torx type screws ?
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Pretty much the same, If I remember rightly its normal bolt heads to get it off.
    Jun 2009
    Middlesex
    Is it better to remove plugs when engine is warm/hot ?
    11 Post(s)
    I wouldn't have thought it made much difference, but when a car is in for servicing, most of the time the engine will be warm from either the customer dropping it off, or by simply driving it into the workshop.
    Jun 2009
    Middlesex
    I have never changed the plugs before.What type of socket/length of extension bar do i need as i believe they are deep into the engine.
    11 Post(s)
    A 16 mm plug socket, according to the how2 link up above. Looking at the how2 pictures, they're in slightly deeper than the length of the socket part of the tool.
  1. Spark Plug check Z22YH engine
    By omega2498 in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2011, 09:33
  2. spark plug renewal interval (2004 2.2 direct)
    By DaveG in forum Electrical & ICE (including SatNav)
    Last Post: 30th October 2009, 13:48
  3. Replies: 4
    Last Post: 22nd June 2009, 13:56
  4. Spark Plug Advice Needed for GSI 3.2
    By gsi32 in forum Engine & Drivetrain
    Last Post: 21st November 2007, 11:41
z22yh spark plugs
https:www.vectra-c.comforumshowthread.php155978-Spark-plug-replacement-2-2-direct-(z22yh)-advicepage2
vectra c 2.2 direct spark plugs
spark plugs replace interval vectra z22yh
vauxhall vectra c 2.2 spark plugs
z22yh spark plugs interval
what spark plugs to use for z22yh
vectra c 2.2 direct spark plug replace
z22yh spark plug socket size
socket size for z22yh spark plug
opel vectra 2.2 z22yh spark plugs
z22yh spark plug thread
spark plug waxchal omega 2 2
vauxhall 2.2 direct spark plug removal
where are spark plugs on vauxhall direct 2.2
z22yh engine tuning
spark removal z22yh
Z22YH Direct spark plugs
opel zafira 2.2 engine spark plugs
