Results 1 to 2 of 2
Thread: Ford 5W30 Fully Synthetic Oil - Any good?
    Regular Member sheepish's Avatar
    Yorkshire
    Default Ford 5W30 Fully Synthetic Oil - Any good?
    Hi All,
    I've seen this Genuine Ford 5W30 Formula F Fully Synthetic oil on ebay, works out at £15.57 per 5 litres (when you buy 4x5litres)...
    http://www.ebay.co.uk/itm/3207149180...84.m1423.l2649
    ...as I'm not up on oil standards (WSS-M2C913-C), is it any good?
    I've got a 52 plate 1.8LS petrol and change the oils every 10k without fail and it's cheaper than the long life dexos 2 stuff I've used to date.
    Jun 2011
    Herts
    that rating is the same as the A5/B5 standard that incorporates all the other standard 1/2/3/4 so I believe its a higher quaulity/spec than the dexos 2 that vx recommend- though that said it's designed for the newest ford engines and may not be suited to vx. I don't see why not though....
    an expert will be along shortly :-)
  1. Replies: 3
    Last Post: 31st October 2012, 01:48
  2. TRIPLE QX Engine Oil 5w30 Fully Synthetic
    By Fitzy-2.0T in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2012, 20:12
  3. Unipart 5/30 Fully Synthetic, cheap but any good?
    By benholden2010 in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2011, 14:48
  4. 20 litres total 5w30 fully synthetic engine oil
    By hoochydady in forum The 'Off Topic' room
    Last Post: 6th July 2010, 18:04
  5. OIL: Fully Synthetic or Semi Synthetic?
    By mishima in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2010, 21:49
