Results 1 to 10 of 19
Thread: Stinking exhaust
    Regular Member bigdave1701's Avatar
    York
    Default Stinking exhaust
    Got in the car this morning and after about a mile (when I stopped at my sons nursery as the wife opened a back door) I noticed a burning plastic/chemical smell. The wife said its coming from the exhaust so I turned the engine off got out and went for a sniff. between turning the engine off and getting to the exhaust tip the smell had almost gone completely. Started the engine again and drove to work and the smell was back. Again by the time I got to the back of the car the smell had almost gone.
    A visual inspection of the engine & exhaust reveals nothing. Ive checked the brakes and thyre not bound on. Any ideas?
    *EDIT*
    There's only 10 miles left in the tank if that has any relevance.
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Could be cat failing Although its usually an eggy smell
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Quote Originally Posted by Critch View Post
    It would only smell eggy on a petrol engine
    More than likely the smell is being ventilated into the passenger compartment from the engine bay
    Check the condition of the pollen filter
    With the engine running and bonnet up check for smells from the engine bay, then compare within the car
    Lower the bonnet, allow a few minutes to pass then compare
    Does you car have rear seat vents?
    If so, close these and compare
    Regular Member the_riddler's Avatar
    Oct 2010
    Carshalton
    Have you checked your coolant level??
    Some times early stages of headgasket going can smell a little like chemicals if the anti freeze is coming through the exhaust!
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by MrDerv View Post
    Fair enough
    York
    There's been a bit of a warm coolant smell in the cabin for a while but it's not losing coolant. The smell is only really noticeable when stationery with a window or door open.
    *EDIT*
    Pollen filter was new 7 months ago. I checked the scuttle last week and it's clear.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Yeah it would have a vegetable oil smell about it.
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    It could also be a plastic bag burnt onto the exhaust.
    That gives a burning plastic smell.
    It could also be the DPF burning off the soot in it, that gets the exhaust really hot.
    Oct 2010
    Carshalton
    Quote Originally Posted by bigdave1701 View Post
    I might be inclined to see if you can get a pressure test done on the coolant see if there is any exhaust gas presurisng the coolant system.
    It could be going the other way and pushing a little exhaust gas out of the headertank overflow causing the smell etc! You tend to find most smells at the back of the car in the end due to the fact you travel forwards most lol!!
  1. Exhaust hanger broken /rotted from exhaust.please help.
    By Dobs in forum Engine & Drivetrain
    Last Post: 25th January 2012, 21:06
  2. Duel exhaust - where to get a right hand exhaust heat shield
    By Innes in forum Bodywork & Interior
    Last Post: 29th November 2011, 00:47
  3. Fitting Dual Exhaust on single exhaust 2.2 sri
    By sdnatlst in forum Petrol Engine related
    Last Post: 1st February 2010, 10:49
  4. Where to buy oval exhaust tail pipes for signum exhaust
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 17:16
  5. Replies: 7
    Last Post: 22nd August 2007, 21:16
