Thread: vectra cdti 120
    May 2008
    fife
    Default vectra cdti 120
    hi am i able to do a total blank off of the egr system ie blanking off at the egr end and the exuast manifold to
    May 2008
    fife
    anyone got any idea
    Jan 2012
    Gloucestershire
    Why both ends? Most people just blank off at the EGR as it's easy to get at. You will have to live with the warning light (fault code P0400 I think), but the car will drive fine - no limp mode as long as you leave the EGR plugged in as normal. If this bothers you, I believe you can get the ECU remapped to turn it off, but of course you will have to pay someone with the know-how to do it.
    May 2008
    fife
    iv got a damaged pipe that comes from the manifold and my local vx dealer doesnt know wot pipe im talkiing about ang was wanting me to take it off the car to show them but is like a tractor hence i couldv blanked it off that end till i get 1
    Jan 2012
    Gloucestershire
    Oh I see! I don't see why you can't blank at the exhaust manifold, but I've never heard of it being done.
    May 2008
    fife
    i was just a bit scared incase i done damage
    Sound like you are talking about the exhaust gas recirculation cooler. Is it made of stainless steel with a diamond shaped flange that fits to the exhaust manifold. The pipe has convoluted bends at both ends of the pipe and a water jacket in between,the other end fits to the egr valve. You have to buy the whole cooler set up from Vauxhall as you cant buy the ends separately. Cost is over £110 if I remember correctly. So you may want to visit a local breakers yard if you just need the bend at the manifold joint.
    Jan 2012
    Gloucestershire
    Or you just blank it and put up with the EML!
    I agree with Rapala though, if it's the just the convoluted pipes, the breakers is your best bet. You may also need a gasket for the exhaust manifold end (also diamond shaped with a hole through the centre & 2 bolt holes) and a gasket for the connection to the EGR heat exchanger (circular), which fits within the toroidal hose clamp.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Drill a 10mm hole just as good but no eml
    Jan 2012
    Gloucestershire
    I don't think this helps if the leak is in the convoluted pipe section between the exhaust manifold and the EGR heat exchanger though - it sounds like stj needs to replace the damaged pipe or completely blank upstream of the leak.
    Breakers still sounds the cheapest to me if you don't want to put up with the EML from blanking entirely.
  1. 1.9 Vectra CDTi 150 VS 2.0 CDTi 160 insignia Sri
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2011, 11:38
  2. Vectra 1.9 CDTI Sri Versus 3.0 CDTI V6 Sri
    By collateral in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2009, 20:18
  3. 0 to 60 in a vectra cdti 150
    By chrisgettings in forum Diesel Engine related
    Last Post: 25th October 2007, 20:39
