Results 1 to 9 of 9
Thread: delay in the wheels moving
    exeter
    Default delay in the wheels moving
    hi all can anyone help i have a delay in the wheels turning in first gear . the engine revs it sounds like im wheel spinning but the wheels dont move and then all of a sudden the bite . has anyone had this or know what it is . i have had my clutch and flywheel done about 6 months ago and it was fine upto now . please help i cant afford another £400 bill
    Dec 2011
    Seaham
    Sounds like the clutch is slipping to me? Maybe something is sticking, like the release bearing or the clutch lever arm? Check to see if the return spring is ok.
    May 2007
    West Yorkshire
    are you parked on ice?
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Got to agree sounds like clutch slipping
    Mar 2009
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    yep slippin clutch gets my vote
    Cumbernauld, Scotland
    Agreed, I had this about 5% and reported to the VX dealership I use
    They were unable to recreate on three visits and on three services
    The issue was eventually traced to the DMF and what you have described was the final symptom which happened almost every day over a week, the clutch finally failed
    exeter
    they should last longer than 11 months surely. for the clutch and slave cylinder and and the dmf is only 4 months old . i only done 8ooo mile on the clutch and less the 3000 on the dmf . should there be warranty on the parts failing this quick . they where both luk parts
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Was false economy to do 1 with out the other as they will have added to the wear on each other
    exeter
    Quote Originally Posted by Critch View Post
    i know that after i had to do the dmf. but the garage said the flywheel was fine when i had my clutch done.
  1. Replies: 15
    Last Post: 8th January 2013, 10:11
  2. cd 70 delay
    By slugo in forum Electrical & ICE (including SatNav)
    Last Post: 12th September 2011, 18:14
  3. lights on delay
    By chris1804 in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2011, 23:07
  4. Trunk delay
    By lucasss in forum Electrical & ICE (including SatNav)
    Last Post: 25th May 2008, 23:46
  5. Tuning box..........delay
    By diesel dog in forum Diesel Engine related
    Last Post: 6th July 2007, 00:03
