Thread: 2.0 DTI Diesel Drinker!!!
    Regular Member kevinmc's Avatar
    Jan 2012
    Ireland
    Default 2.0 DTI Diesel Drinker!!!
    Hi all getting a little bit worried here, "Vectra 2.0 DTI 04" from a full tank to half way has produced 194miles, so approx.. working out I will probably get around the 350miles to a full tank of Diesel. The "Range" is stating I have 329miles left which deff.. is wrong, the MPG however is reading at 26.2MPG. I must say most of the driving is urban, but surely these cars aren't are sore as this.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    350 for full tank of town driving ain't to bad if ya ask me
    How ever when was it last serviced?
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    I get 32mpg to and from work 12 miles a day clear run in morning but traffic on way home for half of journey.
    Sent from my iPhone using Tapatalk
    Oct 2010
    Walkden, Manchester
    As critch said 350 around town aint bad
    Jan 2012
    Ireland
    Car is going in hopefully this week, Oil & filter, fuel filter etc.
    Jun 2011
    Herts
    depends how you drive it. if you drive it like its apetrol you'll get petrol type mileage returns. that said though- if sshe's not getting warmed up and oly doing very short journeys/sitting in traffic I reckon you should still be gettin 30+
    Oh and lad- make sure she's going into 5th- not back into 3rd lmao
    Regular Member Legion84's Avatar
    Jan 2012
    Stockton On Tees
    Quote Originally Posted by kevinmc View Post
    I would say that was pretty poor mpg, i'd say you should be at least hitting around the 40mpg mark, i worked out at the moment we're getting around 41-43mpg, changing the filters should help
    also some people suggest using diesel from shell/esso or bp.. rather than the supermarket fuel as it goes that bit further, and i hear the winter diesel doesn't give as good as it does in warmer weather?
    also check the tyre pressure to did this the other day one of my tyres was pretty low 21psi when i think they should be 33psi i put them upto 30-31ish cause of the ice and snow,
    would people suggest if 5th gear really is better than 4th around town? i find mine can run 5th around 30mph but i find changing to 4th alot and back to 5th, and it seems to run smoother in 4th till about 35mph?
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    my 2.2direct auto does the same as that around town
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    My old DTi gave reading BC readings of 47 normally, rising to over 50 on a good run.
    A good Service, new air filter, air filter mod, new thermostat if necessary, cleaning the inlet manifold, removing the catalytic converter are all going to help with better MPG. Lots of info in the HOW2 section, it is worth paying membership for.
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. V POWER DIESEL Vs DIESEL
    By OSSY in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2009, 21:22
  3. BP Ultimate Diesel vs Morrison's mucky Diesel
    By Big Knox in forum General Chat
    Last Post: 31st March 2009, 13:11
  4. Cider or Beer drinker and why?
    By joules2.0t in forum The 'Off Topic' room
    Last Post: 30th August 2008, 05:31
  5. Shell Diesel Extra Or BP Ultimax Diesel
    By tonyx420 in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2007, 13:25
