Results 1 to 10 of 13
Thread: Headlight wiring burnt?!
    Regular Member Thom's Avatar
    Nov 2010
    UK
    Default Headlight wiring burnt?!
    Yesterday i thought my headlight bulb had gone as there was a symbol on my dash - today my indicator started flashing fast suggesting a second bulb had gone on the same side, after checking the headlight wiring under the rubber cover i can see its charred and now very loose. it looks like its literally burnt itself out.
    Any idea how or why this has happened and what i now need to replace, surely the fuses should have covered this?!
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    One of power wires has been shorting out and caused it to burn
    scottish region
    You have 100w bulbs or that in
    Nov 2010
    UK
    Cheers critch, and ive got standard specced bulb david
    Engine : 1.9 CDTi
    Normally the connector gets corroded and causes poor contact so draws more current and that happens.
    You can buy repair bits: http://www.ebay.co.uk/itm/H7-HEADLAM...item1e609a3b35
    May 2008
    Tyneside
    This happened to mine. When plugging the bulb in someone hadn't located the lug correctly in the lucas connector but behind it. This poor connection eventually overheated and burnt the wiring.
    Nov 2010
    UK
    so i can literally just buy that repair and all my problems are solved?
    i know i need to have a proper look at it yet like because like i say, my indictaor has gone too - that kit wouldnt fix it, no?
    Engine : 1.9 CDTi
    Depends what is wrong with the indicator.
    Nov 2010
    UK
    The indicator bulb was fine, it appears its earth shares the same earth as the headlight bulb.
    The headlight bulb had blown and the connector it was joined to was melted, rather nastily!
    we have isolated the cables from one another until the new h7 2 pin connector arrives and then we'll refit.
    im surprised the 10amp fuse hadnt gone.
    Nov 2010
    UK
    Well that connector appears to have at least allowed my indictor to work again which is good, going to solder the connections tomorrow and put it all back in. ****** Vauxhall electrics.
  1. Halogen and Xenon Headlight wiring
    By jimmyfloyd in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2012, 06:04
  2. Facelift headlight wiring
    By Aikon58 in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2011, 22:10
  3. Facelift headlight wiring
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2010, 12:24
  4. Headlight socket wiring diagram
    By raggy41 in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2010, 20:57
