Results 1 to 3 of 3
Thread: What goes?
    Dec 2011
    Seaham
    Default What goes?
    Bang, crunch, graunch and the smell of rubber and makes your front wheel fowl the wheel arch?
    Just pulled away, was a loudish bang as if brakes had stuck on and then freed off.
    Then you realise that the sound gets worse when you try to turn the steering wheel and you suddenly have no travel in the front suspension.
    Yep, you have guessed it, looks like the front spring has snapped, as its dark and wet I cant confirm it yet, but can't think of anything else obvious it could be!!
    Engine : 1.9 CDTi
    Yep spring broken and either allowing your tyre to sit on the inner arch or as what happened last week one came in with the spring against the tyre.
    Dec 2011
    Seaham
    So fellas, dont want lowered springs, can you recommend a decent make of springs?
