Results 1 to 10 of 28
Thread: thermostat
    Regular Member fiend61's Avatar
    Nov 2011
    york
    Vehicle : vectra 2.8 turbo
    Trim : elite
    Engine : 2.8 turbo
    Default thermostat
    hi all
    car temp gauge barely lifting off 80% when driving, left sitting idling it will climb until driving again then will drop rapidly, i am assuming this is the symptoms of a stuck open thermostat, now i know they are a right pig to do on the 3.2 v6 vec-c but have someone with the experience to do it but im just wondering what to buy??? just the stat £12 or this http://www.ebay.co.uk/itm/2904461744...84.m1423.l2649
    i have heard that the moulding can break when trying to remove so would option 2 be better to buy or has it got to be from vx ???
    tia
    Nov 2011
    york
    Trim : elite
    Engine : 2.8 turbo
    anybody ???
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Given the ambient temperature I'd say there's not a lot wrong really. If the stat was stuck open you'd be lucky to get the temp guage over 70 in normal driving at the moment.
    If you have any worries just keep monitoring it for the moment and once we get sensible daily temperatures again any fault will be more apparent.
    Regular Member dcm23251981's Avatar
    Jul 2011
    burnley
    It will be quicker and easier and cheaper to change just the thermo as the temp sensor wire is a ****** nightmare to get off if you decide to go for that option you will get a small type cardboard tube press that down and turn to release the old stat then its same when fitting new mine works like a dream now
    Nov 2011
    york
    Trim : elite
    Engine : 2.8 turbo
    Post
    Quote Originally Posted by Handyandy-UK View Post
    sorry yes i meant 70 it just doesnt move unless i am stationary as soon as i start driving it drops rapidly down to 70 again
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 129000
    Quote Originally Posted by fiend61 View Post
    your thermostat needs replacing
    i changed the thermostat and the needle stays at 87 to 89 and stays there it should not move.
    when you put the heater on it drop just a tad to 86
    when you are in traffic it may rise to 92 then back to 89 once you start moving again
    my thermostat broke at 53000 miles fixed now because i was getting bad mpg
    the classic sign of a faulty temperature gauge is
    it sits at 0 for ages, moves up to 80 then drops back to 0 again
    ive had a new thermostat fitted now its better on mpg heats up quicker
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 129000
    diesel} takes around 6 miles to get to 86 -87 and the needle stays there
    { petrol} takes around 3 miles to get to 87-89 and the needle stays there
    depending on weather outside say 6 degrees and speed doing
    if you turn your heater on and the needle falls back to 70 to 75 its broke
    i know because mine broke
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Ah... yes, slight difference. 80 wouldn't be a huge problem given the current ambient temperatures.... 70 however, as Ste has pretty much covered, would be getting me concerned.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 129000
    thermostat test
    1.8 petrol
    i did a test today starting from a cold start
    the temperature showing in the car for outside was 6 degrees
    i set my mileage counter to zero and started off driving
    please note my heater is in the off position
    it took 3 miles for
    the needle to rise up and stays at 87 to 89 and stays there
    there is movement of the needle if you put your heater on setting 4
    but this goes to around 83 to 85
    if the needle is between 70-75 you need a new thermostat
    hope this helps because i replaced mine when it broke
    the cabin gets hotter
    mpg is better as well
    Here's a tip to get the engine up to temperature quicker.
    Don't put the heater on in the car until you see the needle rising as all you're doing is taking out what little heat is being generated.
    Let the engine warm up a bit before demanding any warmth from the heater.
    If I put the heater on when I set off for work in the morning (6 mile journey) then the engine temp only gets up to 80 deg max. However if I wait until the needle starts to rise (within 2 miles of the journey) before I put on the heater then within 4 miles it's fully up to temperature.
  1. Thermostat
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 19th February 2012, 22:42
  2. Can anyone tell me what a thermostat does?
    By twinxster in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2012, 22:03
  3. Thermostat?
    By killa_uk in forum Engine & Drivetrain
    Last Post: 31st January 2012, 18:35
  4. can it be anything other than the thermostat
    Last Post: 20th January 2011, 22:36
  5. thermostat or thermostat kit?
    By IA76 in forum Engine & Drivetrain
    Last Post: 24th September 2010, 11:33
