Results 1 to 10 of 24
Thread: 1.9 egr
    Nov 2007
    lancashire
    Default 1.9 egr
    does anyone know if the solinoid part of the egr is the same on both 120bhp and 150 versions????
    Jan 2012
    Gloucestershire
    Hi,
    Not sure whether the solenoid is the same, but as you have the 120 (previous post) then the solenoid, if not moving freely, may be able to be salvaged by drilling a small hole through the back of the electrical connector and punching the press-fit barrel out. It's really very easy; drill, punch, clean, refit! For a better description of what to do, find the How 2 on cleaning the EGR.
    I did mine about 4 years ago and no trouble since.
    Good luck.
    Nov 2007
    lancashire
    solinoid moves freely and did the mod a few years back myself but now have lack limp mode issue!
    Jan 2012
    Gloucestershire
    Have you checked the vacuum hoses? The two small rubber hoses that run from the vacuum unit at the near right (as you stand at the front of the car looking in at the engine bay) to the solid pipes that sit at the front of the camshaft cover are prone to splitting, particularly at the elbow connections.
    Nov 2007
    lancashire
    yup even getting boost, can see this with air pipes swelling up. think im goan bite the bulit and buy another egr, when i swapt solinoids with a friend with a 150 his egr had seized but the solinoid was free so maybee his had fault as well.
    Jan 2012
    Gloucestershire
    If the solenoid is working ok and the EGR valve moves freely (free of crud and can be moved with your thumb from the end where the solenoid contacts) then I can't see the EGR being the problem.
    Easy checks are removing your throttle housing and checking the condition of your inlet manifold and throttle housing butterfly valve - 7mm hex on the large inlet hose, 3 bolts to remove the throttle body (new gasket required if you're being picky!).
    Also, boost sensor which sits in the inlet manifold can get clogged up,. Can be removed with the one retaining bolt, but may need to loosen the EGR from it's mounts first.
    Any other symptoms?
    Nov 2007
    lancashire
    not sure if the solinoid is working, is there a easy way to check this????
    Nov 2007
    lancashire
    only symtoms are emmision light on and wont rev past 2000rpm and very low on power!!
    Jan 2012
    Gloucestershire
    Take a look here...
    http://www.vectra-c.com/forum/showth...=134243&page=2
    "The Wizard" explains how to check the solenoid - basically you need a 12V DC power supply and some wire.
    Nov 2007
    lancashire
    denifinatly more serious, had it on diagnostic machine and showinf faults on egr(BRAND NEW) maf senser , throttle body or sender and somthink else and all reading low voltage so looks electrical unless a ecu does all all of these. not really sure were to go from here, mechanic is looking at harness as he says hes had a few rub through over gearbox area!!!!!
