Thread: Auto dim mirror with small surround
    Engine : 1.9 CDTi
    Default Auto dim mirror with small surround
    Just been playing with my spare auto dim mirror that I am going to be fitting into my sons Corsa C.
    I cut the connector off (You could remove the pins from the connector then refit if refitting to a Vectra C) then pulled the mount out of the mirror and fed the loom through the hole so it was free from the mirror.
    I then cut the 'wings' off and ground a groove in the side for the loom to fit into.
    Next up take the original Vectra mirror with the small surround and also pull the mount from it so you can remove the small cover. Drill the small cover hole a bit bigger so it goes over the dimming mirror mounts ball.
    I have used some double sided foam pads to secure the plastic surround and stop it moving when fitted into the car.
    Now reassemble and you have an auto dimming mirror with a small surround.
    Regular Member farley2708's Avatar
    antrim n.ireland
    very tidy job there man,was thinking of something similar but just went & fitted the cover from a zafira,still a bit of 'space' but not as bad as the vec cover/rainsensor mount
    zafira cover
    Engine : 1.9 CDTi
    I cut a bit of window tint for my car so I could use the full size surround.
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    Lee is there a pic available of what it looks like fitted from inside and outside you could show me please.. I have one to fit with a loom and like the idea of cutting the wings off for a tidier install... Did you used the existing mount on the windscreen?
    Also how the hell do you get the existing mirror to come off the mount?
    Quote Originally Posted by lee gsi View Post
    Me 2 mate......nice 1 Lee..
    Engine : 1.9 CDTi
    From the outside you cant see it at all as its the same footprint as a normal mirror but inside the Corsa C there is a bit of a gap between the surround and the roof lining so you can see the wire a bit but I put it in black heatshrink so you can't see it unless looking for it.
    I used the original screen mount as it just slides on.
    To remove the old mirror the surround unclips a bit and you should see a small 'P' shaped clip that you pull towards you (Away from the screen) that will release the clip so it will slide off (Down) the screen. I used a right angle pick and also a small headed screwdriver to release the clip.
    If your still having problems removing it when I am that way next I will show you.
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    thanks.. will have a look tomorrow.. i can't check tonight its too cold and i and sick as dog..
  1. For Sale: Auto dim mirror, surround and JL sensor
    By lee gsi in forum Parts for sale
    Last Post: 17th November 2011, 17:15
  2. Door mirror surround
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2010, 18:08
  3. Mirror surround and Griffen badge
    Last Post: 26th June 2010, 19:45
  4. Help needed - Auto dim mirror & poss auto wipers
    By mark_647 in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2009, 01:09
  5. A small auto-bio of my car so far 56k BEWARE!...
    By Kev_A in forum Quick Photo Album
    Last Post: 10th January 2007, 08:40
