Thread: CID & Avg Consumption?
    Jan 2012
    Merthyr Tydfil
    Default CID & Avg Consumption?
    Hi guys,
    I've fitted a CD70 and CID in my car which I got for a BARGAIN price of 150 but on the main screen it only displays Range & Ins Consumption. How do I change this to show Avg Consumption instead of inst?
    Jazz.
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    sounds like you need to activate the BC function using tech2 or Opcom
    Jan 2012
    Merthyr Tydfil
    I have BC1 & BC2 but I want it on the main screen not in the menu plus I have to reset it everytime I start the car
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Tech 2 and change the code index
    Jan 2012
    Merthyr Tydfil
    Opcom do the same job? What's the right code index?
    Regular Member Robsey's Avatar
    North East Cheshire
    6 Post(s)
    Trim : Energy
    Mileage : 101,000
    OpCom devices aren't discussed on Vectra-C.com, however there are external forums available for that.
    Regarding your display - have you got all the wires in your display connector
    You should not need to reset the display / head-unit every time you start the car.
    You should have
    Pins 1 and 2 are brown - earth
    Pins 3 and 5 are red - permanent live.
    if pins 2 or 3 are not populated, then link them as described (1 to 2 - 3 to 5).
    If you already have BC1 and BC2, then you do not need to change the code index value.
    It would only need to be changed, if the consumption figures are inaccurate.. diesel figures instead of petrol or vice-versa.
    The main BC page will only display Range and Instantanious Consumption. Only the menu pages will display the other values you desire.
    Tech 2 and Op-Com cannot change this.
    Jan 2012
    Merthyr Tydfil
    How do you link them? I seen the How2 but doesnt say how? What sort of cable and connectors in the quad lock?
    North East Cheshire
    6 Post(s)
    Trim : Energy
    Mileage : 101,000
    I just get a connector from a scrap vehicle,
    then extract the pins from the donor connector with a length of wire, fit the pins to the car's connector, and the solder / sleeve the wire from pin 1 to the wire on pin 2...
    Then do the same for linking pin 3 to pin 5.
    Just check which pins you have...
    Also check / replace your fuses in the passenger end of the dash panel
    Fuses are
    F1 = Head Unit / Infotainment
    F7 and or F9 = BCM
    F10 = CIM module
    F12 = BCM Voltage overload protection
    F17 and F19 = BCM
    F26 = Display / Infotainment
    I know it sounds odd referring to other modules, but they do communicate and therefore have an effect on the infotainment system.
    Jan 2012
    Merthyr Tydfil
    I don't seem to have any problems with the unit and if what you've said is correct about not getting avg consumption on main screen there's no point complicating the issue further. If it ain't broke done fix it
    North East Cheshire
    6 Post(s)
    Trim : Energy
    Mileage : 101,000
    Ah - I thought there was an issue because you "Have to reset it everytime I start the car"
    Yep my feelings exactly - If it ain't boke, don't fix it.
  1. oil consumption
    By otto in forum Engine & Drivetrain
    Last Post: 1st February 2012, 22:37
  2. Consumption value says: F Pls help!!
    By weird in forum Electrical & ICE (including SatNav)
    Last Post: 16th June 2011, 14:10
  3. Oil Consumption
    By johnnyallen in forum Engine & Drivetrain
    Last Post: 23rd June 2010, 21:31
  4. How much oil consumption is too much?
    By _ZS_ in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2009, 19:38
  5. 3.2 consumption
    By vectragsi3.2 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2008, 20:17
Опель Вектра avg. consump
