Thread: Boot light?
    Regular Member lew1984's Avatar
    Jul 2011
    Cheshire
    Default Boot light?
    Hello again,
    Is it standard for the Vec's to have a light in the boot once it's opened?
    I really needed a light in the boot lastnight so luckily I had my flash on my iPhone. I've looked around and couldn't see anything.
    Is this something that can be added? If so is there a how to on it?
    Lew
    Regular Member Big Red's Avatar
    May 2011
    Dudley (Cramlington)
    mate your light should be on the left hand side behind the passenger side light when you open boot as far as im aware every vec has them?
    Jul 2011
    Cheshire
    Quote Originally Posted by Big Red View Post
    I'm assuming it should be located where the rectangle hole is?
    I pulled out loads of wires and I'm assuming this is the connection for it?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    yes correct.
    Regular Member dcm23251981's Avatar
    Jul 2011
    burnley
    as a temp fix take out your glove box light and use that
    May 2011
    thats it matey! you can easily pick them up cheap or you could get an led strip light and place it under the left side of boot were parcel shelf clips in its a nice little mod as the standard one is rubbish lol. all you have to do is run the wires along side the boot and there are some slots on the underside and pop wires through there, dead easy lol
  1. New boot light
    By bobssignum in forum Styling
    Last Post: 19th May 2011, 10:56
  2. Boot light, should I have one ?
    By sharpo in forum Bodywork & Interior
    Last Post: 27th February 2010, 13:49
  3. boot light
    By samuel hosick in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2010, 13:07
  4. Boot light
    By tabster in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2010, 15:23
